Author Topic: Irmscher bumper foglight connectors.  (Read 1702 times)
ted_one
« on: 09 October 2014, 22:04:04 »
Just had a call from the body shop saying that the foglight connectors on the Irmy bumper are different to the standard facelift bumper that's come of my car,and unfortunately part of the Irmy connector is missing so unusable.Question is can I just chop off the u/s connector from the Irmy bumper and then splice the facelift plug/connector in to do the job or something else :-\
Re: Irmscher bumper foglight connectors.
« Reply #1 on: 10 October 2014, 01:12:57 »
Just splice :y
Only two wires, one positive and one negative for each light, both connect to a common feed and ground...
The other two wires at the plug above the horns are for the outside temp sender :y
ted_one
« Reply #2 on: 10 October 2014, 10:40:20 »
Thanks Al,I'm not picking the car up until over the weekend and so I hadn't seen the problem,so was asking the question in anticipation of having problems' as is the norm'' with the Omega. ::) :y
« Reply #3 on: 10 October 2014, 13:27:51 »
At least the Irmscher bumper on the face lift gives you room to access the wiring from above easily enough :y
Page created in 0.011 seconds with 18 queries.
