Author Topic: VW Passat trouble codes help  (Read 4892 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 11 October 2014, 12:44:40 »
Hi guys,
Just put the code reader on the wife's dad's Passat (engine code AJM). Got the following:
A quick Google search has thrown up some interesting replies.... one is checking vacuum hoses... I checked them manually and cant find any issues. Another thread says N75 valve is fekked.
Os, the MAF code.... new MAF?
Anyone know? :)
RIP Paul Lovejoy
4x4
Re: VW Passat trouble codes help
« Reply #1 on: 11 October 2014, 12:47:24 »
Try cleaning maf 1st and see if that helps  :y
And clear codes before refitting it.
Webby the Bear
  • Northampton
« Reply #2 on: 11 October 2014, 12:50:20 »
Thanks Martin, will do  :y
Got a feeling its the top code that's the real problem. Note the car has ZERO power lol
Should I also pop that front hose off to geta look at the turbo...
RIP Paul Lovejoy
4x4
« Reply #3 on: 11 October 2014, 12:55:18 »
Are them vacum hoses braided rubber?
Webby the Bear
  • Northampton
« Reply #4 on: 11 October 2014, 12:57:20 »
I think they're braided. They're not the normal rubber oneslike on the omega
RIP Paul Lovejoy
4x4
« Reply #5 on: 11 October 2014, 13:00:10 »
They may look ok,but for the age of the car i would replace them with silicone  :y
Webby the Bear
  • Northampton
« Reply #6 on: 11 October 2014, 13:03:24 »
ok thanks mate. for the sake of a few pence I may just do that  :y
looking at the articles on the internet ive got a feeling it may be this n75 valve. but obviously need to confirm that cos I think its quite expemsive
RIP Paul Lovejoy
4x4
Webby the Bear
  • Northampton
« Reply #8 on: 11 October 2014, 13:42:07 »
Thanks Martin.
Here's the bad boy in question...
Got 37 ohms resistance and got supply voltage. The link doesn't list the spec of the AJM engine code but I'm assuming I have the higher resistance one.
Am I right in thinking that these can fail even if the resistance is correct? And that failure comes down to a clogged turbo vane(s) thus I should still check the turbo itself.
One oddity I found was that where one of the braided lines from the N75 clips to the plastic retainer it seems quite worn (but no notable holes). I squeezed this with engine running and engine note changes.
RIP Paul Lovejoy
4x4
« Reply #9 on: 11 October 2014, 13:49:40 »
Change that pipe then,and then see if it does the same after.
Webby the Bear
  • Northampton
« Reply #10 on: 11 October 2014, 14:03:33 »
Thanks Martin.
Here's a gret reply from someone off one of the forums...
04 1.9tdi fault codes + loss of power until engine - puggered
engine management light on again, fault codes read (manufacturers)
 18062 electronic instrument panel p1654 intermittent
 17957 control valve boost pressure - n75 open circuit / short with ground. p1549 intermittent
 18080 cooling fan control 1 open circuit / short with ground p1672 intermittent
 19586 egr system control range exceeded p3130 intermittent
 17964 turbo pressure control - control limit below minimal level p1556 intermittent
 Like Reply to this message | Report message as offensive | Link
Tue 3 Jun 2008 18:24  Back Top End
04 1.9tdi fault codes + loss of power until engine - Screwloose
 That's better. There's my old friend 17964. [Him and his mate '965 make the trade millions.]
 As suggested; start with the turbo wastegate vacuum solenoid. It should read about 14-20 Ohms across the terminals. If it doesn't - bin it. If it does - check the wiring.
 Then check the operation and cleanliness of the EGR valve - could be stuck open and venting boost pressure.
 The instrument pod one is a "reflection" code; check the real one in the pod's own memory - could be the oil level sensor; if so, check the bonnet catch switch isn't adrift.
 After fixing all those; [the cooling fan isn't part of the limp-home, but check it and it's relay anyway] re-try it and hope 17964 has gone - if it returns, it'll likely need the turbo actuator checking for stiffness, or the turbo off and the vanes cleaning - don't fit an exchange turbo.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #11 on: 11 October 2014, 14:04:03 »
In short I think I should be checking that turbo also...
RIP Paul Lovejoy
« Reply #12 on: 11 October 2014, 14:08:30 »
If that hose makes a noise when you squeeze it, it has a hole in it.
Change it.
Then report back.
Simples :-*
If the vacuum system doesn't work properly, then the sensors won't work accurately because they can't tell what is happening.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #13 on: 11 October 2014, 15:09:59 »
Another thing you can try Webby before you get stuck too far in is to disconnect maff sensor and drives the car,it'll run a lot better without it than it will with a breaked one connected,thatwill throw a code up which you delete with yer tool :y
other rides
Webby the Bear
  • Northampton
« Reply #14 on: 11 October 2014, 18:18:31 »
Thanks guys!
I'm sure I have some thin diameter vacuum line knocking around.
I'll also disconnect MAF and see what I get  :y
RIP Paul Lovejoy
