Author Topic: Door Strips PFL Removal  (Read 4642 times)
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Door Strips PFL Removal
« Reply #15 on: 14 October 2014, 12:23:06 »
Dont like it , begins to look like an astra  ::) ;D :P Each to their own of course  :y
Don't worry that one got severely  front and back after I sold it to another member  :'( Best Omega I ever did own that was. I did colour code the washer jets and add smoked repeaters which improved it further.
« Reply #16 on: 14 October 2014, 12:27:23 »
Still prefer the pfl shape and interior , especially of the MV ... pfl bumpers are becoming hard to get now  :( and the trim
« Reply #17 on: 14 October 2014, 12:33:13 »
.... I did colour code the washer jets and  ....
I think I must've been the only one to get shut of my bonnet mounted washers & go with the facelift washers in the scuttle  :y
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« Reply #18 on: 14 October 2014, 18:59:48 »
Greetings guys,  I recently have removed both types of door strip.  Facelift ones are held in place with a screw either end and then slide to release the clips that are attached to the strip, easy to do once door card is removed.
The Mini facelift are a little harder. As has been said they are held in place with bonding tape strips, top and bottom, and two clips towards each end.  To remove you need to break the bond, here's how I did it.  Use a wide wall scraper and gently ease between tape and strip (bottom first) you will be able to feel it. It is then possible to ease /slide the scraper along the length of the strip, do it in stages.  Once the lower edge is done tackle the top edge in the same way, always keeping the scraper between the tape and the strip. Keeping the scraper at a shallow angle will mean this can bee done without damaging the paint work. Once free of the tape slide to remove the clips from their recesses .To remove the old tape you the need to use a Toffee wheel No I'm not kidding.  It's a wheel that is the colour of Caramac, fits into a drill and is a none aggressive, even smells like toffee too  :y
To replace the strips, clean up side that sticks to car and spray with a rust preventer, I used Bilt-Himber Electrox . Then run two lines of your favourite bonding agent, I used Tiger Seal and re-apply.  The two clips will hold it, just put some tape either end till fully bonded.
I managed to get mine off with no damage to either paint or strip. Just take your time
Then stand back and congratulate your self on a job well done.   :y :y
Awesome Roland!!
Thanks a bunch!!!  :y
Ant
You're welcome  :y
The faster you go the bigger the grin.  Trade card user.
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« Reply #19 on: 16 October 2014, 15:40:51 »
Just rip them off and fit facelift ones :y
Shop carefully and get them in the correct colour, and you'll get the desired effect for next to no effort :y
Arethe FL ones compatible?
Still learning...Be nice!
« Reply #20 on: 16 October 2014, 17:33:16 »
Yup :y can also swap the whole door over if yours are a bit rusty...
