Author Topic: Another td chip thread...  (Read 10001 times)
maracus
  • Cambs
  • Hahaha cool- 1000+bhp combined on the drive!!!!!!!
    • 3.0mv6 auto, cav4x4 turbo
« on: 13 October 2014, 15:33:19 »
I have just opened up ecu's on both my old chipped pfl manual td and my new facelift td so I could see if I could pull the chip out my old and into the new.
Chip no. on the chipped chip is (I think, my memory is poor and the photo I took is grainy) 342??... And the "new" car chip no. is 1 037 355 972 / 0 281 001 427 on the one that gets swapped. Two questions,
1) who do I speak to to get a socket sioldered on (local to cambridge/peterborough (maybe for a 12 pack of beers??)
2) can I use the chip I have or do I need to buy a new one?
Marcus.
The weather is here... Wish you were beautiful!
Re: Another td chip thread...
« Reply #1 on: 13 October 2014, 18:08:15 »
1) any local electronics repair place (try small, independent TV repair shops)
2) Assume you've bought a map and have a programmer then? If so, worth taking copy of existing map before overwriting. Personally, I'd use a new chip, and carry the original around in case an unexpected problem occurs...  ...some of these ebay maps are absolutely awful.
maracus
  • Cambs
« Reply #2 on: 13 October 2014, 18:39:49 »
No that sounds expensive!... i was under the impression that there's four different chips depending on what the numbers on the chip are.. Have I got that right?
If I needed a different chip I was going to drop a PM to the guy I brought the last one off. Although Id hope that I could save £40 and use the one I've already got..
Wil try local electrical places then  :y
« Reply #3 on: 13 October 2014, 19:42:55 »
There are lots of different maps.
The cost of a blank chip is probably around £5-10 (gone up a bit recently, I guess not as common as they once were)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 13 October 2014, 20:00:33 »
I think the OP is asking whether the Old Chip from He's PFL will fit into His new FL?, rather than copying the Map from it.?
« Reply #5 on: 13 October 2014, 20:04:41 »
OK, what age and gearbox is:
The old TD
The new TD
maracus
  • Cambs
« Reply #6 on: 13 October 2014, 21:46:06 »
That's what I meant haha!
Old td; manual, on an N plate,
New td; manual, on a V plate.
Will check the years when I get home as can't remember off the top of my head  ::)
« Reply #7 on: 14 October 2014, 14:06:23 »
Nope, wont work
maracus
  • Cambs
« Reply #8 on: 14 October 2014, 15:05:54 »
Drat!
Best wait for payday then  ::)
« Reply #9 on: 14 October 2014, 21:22:04 »
N reg will be 1996, so borderline. Did it have a MAF? Do you still have old ECU, if so, are last 4 digits 214?
maracus
  • Cambs
« Reply #10 on: 15 October 2014, 09:01:24 »
Yep.. It is indeed a '96  :y no AFM on that one, but there is one on the new one... On that, I thought they'd be different but thought I'd ask for sure lol. As for the digits 214... Possibly, haha! Is that on the ecu casing or the actual chip itself?
zirk
  • Epping Forest
« Reply #11 on: 15 October 2014, 10:00:59 »
ECU Casing, theres a Blue or White lable from memory with the Boosh ECU number on there, although its been a while.
zirk
  • Epping Forest
« Reply #12 on: 15 October 2014, 10:17:13 »
Found a old pic if it helps, the ECU on the left was from an Omega TD's, N reg with no Maf. last Digits 214.
Forget the one on the right thats from a BM TDSE.
maracus
  • Cambs
« Reply #13 on: 15 October 2014, 15:37:24 »
Just had a look and yep it's a 214 on the old one  :y
I thought that number sounded fimiliar!
« Reply #14 on: 15 October 2014, 20:13:36 »
Methinks you need a new chip ;D
