Author Topic: Front passenger door....  (Read 4522 times)
williexjr
  • Glasgow, Scotland, UK.
    • 2002 Omega 2.2 diesel
« on: 13 October 2014, 20:53:50 »
Good evening gentlemen.
Had this problem for a couple of months now but I really need to try and sort it now.
2002 2.2 deisel.  The front passenger door lock is jammed. All other doors lock/unlock without any issues.
How can I get the door to open to remove the door card to enable me to get into the 'workings' of the mechanism????
Any help in this matter would be great.....I'm at a loss!!!!
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Front passenger door....
« Reply #1 on: 14 October 2014, 16:21:50 »
Have you tried pliers on the internal unlock knob? They can be really stiff if the motor switch has failed. On my Elite when the switch had failed, if I inadvertantly locked it with the deadlock, I had to use pliers and a piece of rag to lift the selector to unlock.
If you have tried all this you may have to sacrifice the door card to get in, and pick up a spare from the scrappies. :y :y :y
williexjr
« Reply #2 on: 14 October 2014, 18:15:59 »
Thank you for your reply....No, I haven't tried using pliers but I will give that a go and let you know how it goes.
Thanks again - always appreciate the helpful knowledge  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 15 October 2014, 09:35:26 »
In theory you should be able to pull up the locking pin with pliers, so I second that. Also a replacement will be pence from a fellow OOFer, also they're the same as on Cavs, Astras Corsas etc.... so not hard to course replacement  :y
williexjr
« Reply #4 on: 15 October 2014, 22:05:40 »
 :y :y :y
Again, the owners club members have came to my rescue. Thank you!
The button pulled up with a little force using pliers and I reckon I can live with pushing and pulling the knob manually in future.
The bad news is my 'CHECK COOLANT' warning came on and when I parked the car I noticed coolant pouring from behind the area of the drivers wheel.....too dark and wet to check it tonight though :(
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #5 on: 15 October 2014, 22:21:33 »
:y :y :y
Or you could replace the door locking solenoid. By putting a wanted ad on here...Easy job to do  :y
Shackeng
  • Ramsbury
« Reply #6 on: 15 October 2014, 22:37:33 »
:y :y :y
Remember not to use the deadlock, and you can pull it up by hand until you fix the microswitch. :y
williexjr
« Reply #7 on: 15 October 2014, 22:53:01 »
Hmmmmm.......I've used the deadlock and I can still pull it up by hand :y
The coolant problem is now priority, though I will try and source the 'micro switch' from here :y
« Reply #8 on: 15 October 2014, 23:01:36 »
Probably the HBV - behind the engine drivers side - 3 cooling pipes attached plus thin vac pipe to the top ;)
williexjr
« Reply #9 on: 15 October 2014, 23:11:21 »
 ???.......Is this going to be a costly repair???? :'(
« Reply #10 on: 16 October 2014, 01:46:09 »
About £40 and some knuckle bruising :y
williexjr
« Reply #11 on: 27 October 2014, 21:42:48 »
Hello folks....
I have finally got round to having more of a look at my leak!!!!
I took the car round to a friend who has a ramp and it looks like the coolant was leaking from the 'night heater' thing....below the airbox / behind the off side fog lamp.
Now initially when I noticed this leak, it looked like quite a lot but it took no more than 1 litre to top up again.
I then drove the car to my friends place, which is about 10 miles (of slow very very busy motorway) and the car hadn't lost a drop....and there was no signs of it leaking. STRANGE!
The unit itself is very badly corroded and there are signs of coolant on its exterior. I reckon it's only a matter of time before it bursts altogether.
I noticed two rubber hoses going to the top of said 'thingy'.....can you guys tell me if I can link these two pipes and do away with said 'thingy' altogether????
I never use it.....it's something that heats the car with the ignition off, I believe????
So guys, can I bypass it?
Cheers.
« Reply #12 on: 27 October 2014, 22:22:04 »
Cheers.
You don't get a choice in whether you use it.  ;) It runs at low ambient temps (no idea what temp it triggers at) and runs to assist the engine in getting the coolant up to temp faster. Some car makers have a similar set up but have the ability to do as you suggest ie tell it to start a 10/15 mins before you set off to work so you have a pre-warmed engine for your journey.
No reason why you can't by-pass it though.  :y
williexjr
« Reply #13 on: 27 October 2014, 22:25:32 »
Thanks....
What is the 'thing' called?  I presume it would be an expensive part to replace?
« Reply #14 on: 27 October 2014, 22:30:31 »
Thanks....
maybe a diesel pre heater ...... ??? Espacher is a big name in that kind of thing. www.eberspacher.com
