Author Topic: tow bar. will it fit?  (Read 2117 times)
doughall
  • Small village in Wiltshire
  • Here's Tom with the weather!
    • Omega 2.2DTi '02
« on: 14 October 2014, 13:29:27 »
Can anyone tell me for sure if this will fit my 52 plate omega saloon? (it has a boot.)
http://ebay.us/4gVGcb
Thanks.
steve6367
Re: tow bar. will it fit?
« Reply #1 on: 14 October 2014, 13:44:35 »
Looks same as the one I fitted to mine - it is missing the spacer (as they normally are) for the long bolts that go through the chassis rails. You must get these and fit correctly.
Steve
doughall
    • Omega 2.2DTi '02
« Reply #2 on: 14 October 2014, 13:54:28 »
steve6367
« Reply #3 on: 14 October 2014, 14:09:49 »
I used this:
http://www.ebay.co.uk/itm/25MM-OD-X-19MM-ID-3MM-WALL-CDS-STEEL-TUBE-X-400-MM-/321206594646?hash=item4ac967ac56
You can purchase from Witter I think, but I didn't get any joy there.
Steve
doughall
    • Omega 2.2DTi '02
« Reply #4 on: 14 October 2014, 18:33:05 »
Cool. Thanks.. Do I just need two? Do they need cutting or is 400mm what's needed.?
« Reply #5 on: 14 October 2014, 19:00:22 »
As per the photo, they are for the bolts at the far end of the photo ie the end of the tow bar that's towards the front of the car. They go into the chassis box section so that you're bolting to the boot floor & not trying to crush the chassis leg.
steve6367
« Reply #6 on: 14 October 2014, 20:21:46 »
Just 1 of those eBay listing, you will then cut the 2 lengths you need from that. You can download the witter instruction with details  :y
http://www.witter-towbars.co.uk/uMedia/FittingInstructions/G67B.pdf
doughall
    • Omega 2.2DTi '02
« Reply #7 on: 17 October 2014, 14:59:57 »
Ok. Tow bar received. Looking at the witter instruction that was linked above, it seems to be missing the Short Cross Bar. Part "A".
steve6367
« Reply #8 on: 17 October 2014, 23:32:51 »
Ask the seller?
Or try Witter, some report they will send parts.
