Author Topic: Is it ok to keep flooring it...  (Read 5173 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Is it ok to keep flooring it...
« Reply #15 on: 19 October 2014, 14:52:59 »
Another pointer. My car never has Mayo on the filler cap. Not even the slightest sign.
...until they put a contro flow and average speed limit of 50 on part of my commute on the m4.
Now when I get home, there's a slight milky film inside on the cap.
As TB often says, the filler cap is a good sign of what is happening in the breathers as both sit outside the engine. If you have Mayo on the filler cap, you have Mayo in the breathers. ....and the engine isn't getting warm enough, as your not trying hard enough. ;)
....or your commute won't allow the engine to get warm enough.
 :y :y :y :y :y
RIP Paul Lovejoy
ted_one
« Reply #16 on: 19 October 2014, 15:23:30 »
I popped out this morning to give one of mine a bit of a run as it's not been out for a couple of weeks.....I took it down mine and CG'S own private motorway namely the A329M got it up to *** mph and gave myself a bit of a scare as it was a bit damp out there first thing....can't say much more than that ::)
Webby the Bear
  • Northampton
« Reply #17 on: 19 October 2014, 15:34:55 »
 :o ;D ;D
RIP Paul Lovejoy
chrisgixer
« Reply #18 on: 19 October 2014, 15:39:04 »
Ahh the Readingham super highway.... When it's not dug up. ;D
« Reply #19 on: 19 October 2014, 17:07:54 »
Webby , the only thing I will say is keep your oil fresh and dont test the rpm limiter at the N position :y
Webby the Bear
  • Northampton
« Reply #20 on: 19 October 2014, 17:11:16 »
Sweet, cheres cem  :y
RIP Paul Lovejoy
« Reply #21 on: 19 October 2014, 19:40:48 »
No issues, but let it do at least 3 or 4 miles (not just for temp to hit right spot on gauge), and give it a couple of miles to calm back down. But between those times, there is only one throttle position.
« Reply #22 on: 19 October 2014, 21:00:30 »
As long as the Yanks keep fracking and the price of fuel keeps going down, then it's OK to keep flooring it!!  :y :y :y
Webby the Bear
  • Northampton
« Reply #23 on: 19 October 2014, 22:17:44 »
Cheers lads  :y
Four miles softly, mash loud pedal, then relaxing two miles. Got it  :y ;D
RIP Paul Lovejoy
4x4
« Reply #24 on: 19 October 2014, 22:22:10 »
That means you have to drive more than 6 miles everytime you go out  ;D ;D
« Reply #25 on: 19 October 2014, 22:24:05 »
What happens if he becomes a scaredy bear after 4.1 miles? Can he go home, or should he wait... ::)
« Reply #26 on: 19 October 2014, 22:26:57 »
Never mashed my pedal , too afraid of those 6 pots  :-[
Webby the Bear
  • Northampton
« Reply #27 on: 19 October 2014, 22:35:40 »
 ;D ;D ;D ;D
RIP Paul Lovejoy
