Pages: 1 [2] 3  All   Go Down
Author Topic: Flat Spot  (Read 7435 times)
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
Re: Flat Spot
« Reply #15 on: 19 October 2014, 18:51:27 »
Any codes?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Flat Spot
« Reply #16 on: 19 October 2014, 18:52:02 »
Deffo check that vac box  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Flat Spot
« Reply #17 on: 19 October 2014, 18:54:02 »
... As per Andy h .s comment  :y
Just pull smallest pipe off front vac box.no hiss equals either you've doe work and got pipes on wrong way round or box is fubard  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Flat Spot
« Reply #18 on: 19 October 2014, 18:54:39 »
This is with car off btw  :y
RIP Paul Lovejoy
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: Flat Spot
« Reply #19 on: 19 October 2014, 20:33:46 »
Cheers Webby, I'll check it out this week, not checked for codes yet but I'll do that at the same time  :y
Temetsy
  • Finland
    • b1 x25xe sedan
Re: Flat Spot
« Reply #20 on: 20 October 2014, 02:13:31 »
IIRC the v6 has a 'flat spot'/drop on torque/power curve around 3,5k rpm :( I've heard that pumping up fuel pressure would cure that strange flat spot. I have no front multiram (custom intake by previous owner that really kicks sucks *ss) and still get that weird loss of power at that rpm..
Mr Gav
  • Leeds
Re: Flat Spot
« Reply #21 on: 21 October 2014, 22:17:22 »
Well the vac reservoir seems fine, pulling the pipe off and there was a distinct hiss so tonight on the way back from Missy MV6`s I did a slightly untechnical test, a blast along a dual carriageway, first at full throttle and there was the flatspot between 3500-3800 rpm. Then I repeated the test at 3/4 throttle and pulled clean all the way from just below 3000rpm through to 5000rpm.
I still don`t think it`s a misfire, it just doesn`t feel like one, hard to explain but it just doesn`t feel like one.
    • 530D M Sport, 330i Coupe
Re: Flat Spot
« Reply #22 on: 21 October 2014, 22:20:13 »
That power loss flat spot was noticeable on the Vectra B 2.5 / 2.6's but far more smoothed out on the Omega V6's with the help of the Multi-Ram setup.
Webby the Bear
  • Northampton
Re: Flat Spot
« Reply #23 on: 22 October 2014, 11:36:23 »
Ok, so youre getting stored vacuum. thats good.
blip the throttle and watch them operate.
for the rear one get someone to jam it quickly above 5k rpm. observe.
RIP Paul Lovejoy
Re: Flat Spot
« Reply #24 on: 22 October 2014, 12:06:19 »
Sounds a bit like the issue Webby had with a failed non return valve in the front vacuum tank :-\
Yep , first thing to check  :y
At WOT you have very little manifold vacuum so you are reliant on the vac tank storing some
Mr Gav
  • Leeds
Re: Flat Spot
« Reply #25 on: 22 October 2014, 17:50:41 »
Already checked the vac reservoir and it`s holding vacuum, whether it`s holding enough is another question but AFAIK they either work or they don`t.
Next thing is to check the multi rams are working, not too keen on blipping to 5000rpm at standstill with no load though.
Webby the Bear
  • Northampton
Re: Flat Spot
« Reply #26 on: 22 October 2014, 20:51:23 »
You wont be able to see if they're working then ;) As long as it's up to temp. I don't see the issue.
As for is it holding ''enough'' vacuum...
If there's a vacuum leak somewhere else (e.g. brake servo hose) could the vacuum store be depleted thus affect multiram opening operation??? Question to expert...
RIP Paul Lovejoy
  • Auckland
    • Mazda MPV
Re: Flat Spot
« Reply #27 on: 22 October 2014, 22:08:03 »
You did this soon after switching the engine off ?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Flat Spot
« Reply #28 on: 22 October 2014, 22:20:22 »
Why not?  If the engine is up to temperature, you can hold it on the limiter for a second or two.  The limiter is there as a (conservative) limit that the engine was designed to withstand.  These engines happily rev to 7.5k for brief periods of time.
chrisgixer
Re: Flat Spot
« Reply #29 on: 22 October 2014, 22:48:29 »
And it won't stress the engine in the same way as it would be loaded. Anything under the Rev limit is within operating range for the engine. If not there's something wrong.
Pages: 1 [2] 3  All   Go Up
