Author Topic: It's DONE........  (Read 1541 times)
JueV6
  • Kent
It's DONE........
« on: 24 June 2008, 22:18:39 »
Took longer than expected due to 2yr old and SWMBO but.....
IT'S DONE.
here are the pics I took in the process.
I took these of a neighbour's to try to work out the vacuum pipes
[size=56]And FINALLY [/size]
Re: It's DONE........
« Reply #1 on: 24 June 2008, 22:21:37 »
LPG?
What kit?
Where did you mount the vaporisor?
What tank, pipe route?
Did you drill out the injector nozzles?
Any snags?
Where did you get RPM and lambda feeds?
Where did you take the coolant feed for the evaporator?
« Reply #2 on: 24 June 2008, 22:22:42 »
Exhaust manifold gasket, job well done :y
« Last Edit: 24 June 2008, 22:28:02 by Elite_Pete »
Andyb
  • Lincoln
« Reply #3 on: 24 June 2008, 22:22:55 »
cool
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 24 June 2008, 22:25:10 »
well done, looks like a tidy installation  :y :y :y
« Reply #5 on: 24 June 2008, 22:26:13 »
Exhaust manifold gasket, job will done :y
Of course - just saw the pic !  ::)
Still though - be interesting to hear about the LPG
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 24 June 2008, 22:52:43 »
Excellent a job well done :y
« Reply #7 on: 24 June 2008, 22:58:46 »
As a matter of interest would it be any easier to chage the HBV when the Plenum is off, rather that stripping the scuttle panel off?
A bit of a Naive question I know, but not exactly sure where the HBV is.
TIA.   :y
JueV6
  • Kent
« Reply #8 on: 24 June 2008, 23:30:45 »
LPG?
What kit?
Any snags?
Not sure what kit, james, was alredy installed when i got the Elite.
Pic of the vaporiser mounted adjacent to the alternator
, And YES i have just noticed a nut missing from the mounting.
If you want to meet and look then we can arrange something.
Coolant pipes are taken from the heater bypass valve and the coolant bridge. as for the wiring.....NOT A CLUE. ;D ;D
JueV6
  • Kent
« Reply #9 on: 24 June 2008, 23:34:38 »
It's a damn sight more organised now.. It was a real mess, Wires and pipes just laid everwhere.
JueV6
  • Kent
« Reply #10 on: 24 June 2008, 23:37:01 »
TIA.   :y
HBV is right at the back of the OS head on a thin metal bracket. Taking the scuttle off makes it very accessable :y
