Author Topic: speedometer and rpm gauge  (Read 1877 times)
makeitsnappy
  • east texas
    • 98' catera
« on: 20 October 2014, 23:01:16 »
 I've got a problem when I connect the battery back up after performing a repair the rpm gauge doesn't work and the speedometer just jiggles up and down on zero. I had originally turned the key ignition to "on" position but not start for 4 minutes to reprogram sunroof,windows,a/c...ect. I then turned the key to the off position and then started it up and that's when I realized the speedo & rpm gauges where not working. So I shut the car off and turn the ignition back to "on" and waited 4 min. again, and this time with out turning key off I turned key to start and the engine started up and rpm gauge started up and speedometer was steady(not jiggling). So today I start it up and no rpm's and speedo just sits on zero jiggling again. I performed a 4 min. key in "on" position and then to start but it didn't fix it :'( I have a 98' Cadillac catera but its actually a Opel Omega, can someone help me figure out the source of this problem :( It does it just about every time the battery gets disconnected for a good period of time, but it eventually starts back to working again sometimes not until you drive it around for a few days. I thinking maybe its time to figure it out before it completely stops working :-\
Re: speedometer and rpm gauge
« Reply #1 on: 20 October 2014, 23:39:16 »
Try reseating dashboard ;)
« Reply #2 on: 21 October 2014, 00:46:16 »
Failing that, you'll need a new one :-\
Gauge cluster that is...
chrisgixer
« Reply #3 on: 21 October 2014, 09:03:35 »
Page created in 0.009 seconds with 20 queries.
