Author Topic: Absolutely Bl**dy typical!!!!!!!  (Read 3416 times)
Crazycarzowner
« on: 24 October 2014, 13:08:21 »
Car has been starting & running perfect since the heater plugs have been changed. Coming home from Stockport earlier today, stopped off for some bits & pieces, get in the car (still warm) and refuses to start  >:( >:( >:( won't even try, just keeps wizzing over on the starter  :'( :'( :'(
To say I'm p1$$ed off is an understatement, especially when we're supposed to be going away up north for a week in it tomorrow  ::)
GRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Absolutely Bl**dy typical!!!!!!!
« Reply #1 on: 24 October 2014, 13:39:37 »
Try lock and unlock via fob just in case immobilzer is having a moment.
other rides
Crazycarzowner
« Reply #2 on: 24 October 2014, 14:02:32 »
Tried that, no luck. Think its the dreaded VP44 fuel pump issue to be honest  ::) ::) ::)  :'( :'( :'( :'(
« Reply #3 on: 24 October 2014, 14:14:41 »
Fuel pumps  and diesels ........ sounds potentially very expensive  :'( :'(
Crazycarzowner
« Reply #4 on: 24 October 2014, 14:22:10 »
If it is its about £1200  :o :o :o
chrisgixer
« Reply #5 on: 24 October 2014, 14:30:50 »
Are you watching TB...?
« Reply #6 on: 24 October 2014, 14:37:22 »
Similar price to an Astra G ....  :(
Crazycarzowner
« Reply #7 on: 24 October 2014, 14:39:15 »
Just been reading up on the VP44 forums of doom and it seems its not the mechanical part pump that goes tits up, but the electronic module that sits on top of it. Will have to await diagnostic confirmation, but if it is what the symptoms describe then its not as bad as I thought. Effectively you only have to disconnect the bastid or more commonly known EDC unit, from the pump and sent it away to be repaired. £300
« Reply #8 on: 24 October 2014, 14:54:02 »
Just been reading up on the VP44 forums of doom and it seems its not the mechanical part pump that goes tits up, but the electronic module that sits on top of it.  ....
Likewise the Astra's fuel pump and ABS ECUs on the Omega .............. electrickery is only good when it's working.  ::)
Crazycarzowner
« Reply #9 on: 24 October 2014, 18:56:16 »
Well we won't be going away in the Skoda tomorrow, the fault is electrical and when I went to the garage for a progress report the innards of the car looked like spaghetti junction!!!!    :o :o :o :o
Looks like Misses's Ford Fiesta it is then all the way up north  :D :D :D
The Sheriff
« Reply #10 on: 24 October 2014, 18:59:19 »
Can't you borrow a company car? Would make the journey quicker :y
Oh...wait....that would probably break down too. :(
Crazycarzowner
« Reply #11 on: 24 October 2014, 19:03:32 »
Sorely tempted STMO, our 211000 mile plain 2011 Beemer is the most reliable of the fleet!!!  ;D
Crazycarzowner
« Reply #12 on: 30 October 2014, 11:18:21 »
Well, nearly a week on and its still not running. Rang up the garage for a progress report and it wasn't good.  :'( All component parts have been checked, electric current passed through the lift pump in the tank manually ok but as soon as you crank, no fuel coming through to the injectors. Pumps been off & on, timing redone, everything checked & double checked = still won't run!!!
It managed to cough, splutter and bark into life for a short spell, then died again, beginning to think about cubing it right now  :o :o :o
« Reply #13 on: 30 October 2014, 11:32:59 »
Not convinced regarding your garages ability as process seems to be lacking diag and more focused on doing 'stuff'
EDC is the common issue on a VP44, its easy enough t remove and send for testing and would be much cheaper than the multitude of stuff they have done thus far.
Crazycarzowner
« Reply #14 on: 03 November 2014, 19:54:42 »
Well got news I was dreading today, the fuel pump is guffed completely!!!! It has been tested and its not the EDC at fault, the internal workings are mush.  :( :( :( Gonna be expensive  :'( :'( :'(
