Author Topic: fu****g cars  (Read 2866 times)
badmuver
fu****g cars
« on: 25 October 2014, 19:15:04 »
Hi everyone, Been doing a lot of work on the car today change the drivers wishbone, both drop links, and n/s tie rod (o/s was missing should get sometime next week  :()  But I still have a knocking noise when going over holes and bumps and also when I breaks  :'(               confused.
Temetsy
  • Finland
    • b1 x25xe sedan
Re: fu****g cars
« Reply #1 on: 25 October 2014, 19:28:42 »
Maybe stab/sway bar bushes? A guy at OCF had similar trouble and IIRC that was where the fault finally was. Though the clunk you hear when braking may be just old worn calipers, heard many (true)stories of those.
chrisgixer
Re: fu****g cars
« Reply #2 on: 25 October 2014, 19:51:13 »
Not immediately helpful I know, but identify what is causing the knock first/before going any further. Hence your frustration.
There are guides in FAQ and maintanance you'll find helpfull. :)
badmuver
Re: fu****g cars
« Reply #3 on: 25 October 2014, 20:03:08 »
Those bit's need to be change, I will do some more digging around in the morning.
  • Auckland
    • Mazda MPV
Re: fu****g cars
« Reply #4 on: 25 October 2014, 20:39:37 »
If the calipers are loose enough they will rattle over bumps in the road too.
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
Re: fu****g cars
« Reply #5 on: 25 October 2014, 23:06:59 »
Also pattern crap brake pads can move in the calipers.
cjackel492
  • Sussex
    • 2001 Omega Elite 3.0
Re: fu****g cars
« Reply #6 on: 25 October 2014, 23:43:17 »
Could be the steering idler..
Found that caused lots of knocking noises on my Carlton.
Avoid cheap ones thou..
Carl,
chrisgixer
Re: fu****g cars
« Reply #7 on: 25 October 2014, 23:58:25 »
No 1 cause of knocking, Drop links.
After that it could be anything. Wishbone bushes failed allowing the metal wishbne too knock on the subframe. Any worn ball joint. Any seized ball joint. Ant loose bolt. Any wheel bearing. Any.... Anything loose, failed, seized, pitted flattened etc etc
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: fu****g cars
« Reply #8 on: 26 October 2014, 07:43:42 »
Make sure the drop links are tight. Could still be a bit loose as I found out once :y
badmuver
Re: fu****g cars
« Reply #9 on: 27 October 2014, 20:20:58 »
Cheers for all the reply's, turns out the be a bolt for the suspension arm had come loose  >:(  So no more knocking.
chrisgixer
Re: fu****g cars
« Reply #10 on: 27 October 2014, 23:40:50 »
Wishbone bolt? 120nm plus angle tighten 30 then 15 degrees
Pinch bolt to Wishbone ball joint 100nm
....iirc
chrisgixer
Re: fu****g cars
« Reply #11 on: 27 October 2014, 23:42:25 »
Ps, if Oe rubber bushes. Front bolts MUST be tightened wheels loaded. Suspension at normal ride height. Or the bushes will tear and fail early. Very early.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: fu****g cars
« Reply #12 on: 28 October 2014, 08:19:07 »
Which bolt?
badmuver
Re: fu****g cars
« Reply #13 on: 28 October 2014, 20:01:19 »
Which bolt?
It was on the back of the wishbone flat bush. I had it change back last year for the mot.
