Pages: 1 2 [3]  All   Go Down
Author Topic: 3.2 misfiring, EML flashing; now stopped doing it  (Read 5723 times)
chrisgixer
Re: 3.2 misfiring, EML flashing; now stopped doing it
« Reply #30 on: 02 November 2014, 23:17:31 »
Seen too many 3.2's with rusty plug holes to consider the coil PACs water tight. Not even slightly. Not even with silicon grease around the seal.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #31 on: 03 November 2014, 08:15:51 »
Thanks, Chris. That's worth knowing. So what I need is a secondary water shield, on the lines of biggriffin's 'roof' over no. 6 plug hole, made from an old screenwash 5 litre bottle. I suspect the failure of coil packs on pre facelift cars, including in line fours, may also be the result of water on the coilpacks, causing tracking, etc.
Unless, of course, I can seal the scuttle joint satisfactorily.
chrisgixer
« Reply #32 on: 03 November 2014, 15:20:39 »
No I considered that but a shield could come loose or deflect water elsewhere. Better to seal up what's there IMO. It works well when sealed. Nice dry engine bay. :)
Pages: 1 2 [3]  All   Go Up
