Author Topic: 2.2 Auto Box Kickdown Problem  (Read 5889 times)
bigboydal
  • Essex
    • Omega 2.2 Auto
« on: 26 October 2014, 13:44:19 »
Hi all,
I've had my trusty Omega for a few years now. Recently changed the auto box oil and filter but the kicdown just doesn't seem the same now. Basically, the kick down seems to work fine one minute but then refuses to drop whatsoever the next. It normally refuses to drop at mid range speeds, eg 50ish. Very strange as it pulls off from a stop like a missile changing gears lovely but often refuses to kick down when joining motorways etc
I used to love the kick down on this motor! I've re-checked auto box oil level with engine running etc. It did take a bit more and it does seem to of improved the frequency of the kick down refusing to kick down but it still randomly plays up. Obviously as the oil is the only thing I have changed it would indicate that but Ive used DX 4 as required. Any ideas out there for me?
4x4
Re: 2.2 Auto Box Kickdown Problem
« Reply #1 on: 26 October 2014, 13:46:31 »
Ahh thats an easy fix......
Your 2 cylinders short of a proper engine  ;D ;D
bigboydal
  • Essex
    • Omega 2.2 Auto
« Reply #2 on: 26 October 2014, 13:53:18 »
many thanks for your words of wisdom but there has to be another way  :'(
Ive recently changed the cam sensor with a genuine GM part so that shouldn't be causing my grief
« Last Edit: 26 October 2014, 13:56:16 by bigboydal »
Temetsy
  • Finland
    • b1 x25xe sedan
« Reply #3 on: 26 October 2014, 14:29:16 »
Got to love the different attitude you have toward six pots there compared to general oppinion to those lumps here in finland  ::)  ;D
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #4 on: 26 October 2014, 15:16:11 »
Use the big stick in front of the stereo - or even the button on the top of it
Thats what I do when thew computers says NO
bigboydal
  • Essex
    • Omega 2.2 Auto
« Reply #5 on: 26 October 2014, 15:33:47 »
but the computer used to say YES! that's the problem.
flyer 0712
« Reply #6 on: 26 October 2014, 16:31:06 »
I believe that I am correct when I say...I have seen other members on here with autos .and after changing the filter and fluid they too have  had problems with gear changing....dont know the answer but that is why i have never been tempted to change mine just in case the same thing happens....as mine is ok  that old proverb comes to mind....if its ok why muck about with it. :-\ :-\
bigboydal
  • Essex
    • Omega 2.2 Auto
« Reply #7 on: 26 October 2014, 18:25:49 »
any helpful replies would be greatly appreciated
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #8 on: 26 October 2014, 19:19:46 »
I Wonder if it would be any help having a Gearbox software update  :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 27 October 2014, 13:44:11 »
The fact is that changing the auto fluid can mess up a gearbox if it hasn't ever been changed. The old fluid after twelve years will be a lot thicker as it will be made up of tiny metal shards where the gears slip and after replacing it with new thinner fluid has caused a problem.
I don't know what others on here think but I'd be tempted to add some non slip additive to overcome this.
RIP Paul Lovejoy
« Reply #10 on: 27 October 2014, 17:50:03 »
Where did you get the cam sensor from :-\
« Reply #11 on: 27 October 2014, 18:11:03 »
I'd be inclined to get it on diags, and check engine and gearbox for codes, and check the kickdown switch is working reliably.
Webby the Bear
  • Northampton
« Reply #12 on: 27 October 2014, 18:12:18 »
Out of interest how would one go about such a task, TB?
RIP Paul Lovejoy
« Reply #13 on: 27 October 2014, 18:12:22 »
Its a big ask to get 1.7t of lump moving from such a small engine, esp in auto form.
« Reply #14 on: 27 October 2014, 18:12:41 »
Live data
