Author Topic: wanted: estate fuel pipe  (Read 3148 times)
al brown
  • alton, hants
    • Rusty 97 3l estate
« on: 27 October 2014, 20:57:40 »
Hi all, as per title, I need the fuel pipe that goes into the fuel filter (from the tank to the filter). Not sure where the next break up to the tank is, but I have broken mine where it meets the filter.
Don't suppose it matters but it is for a pre facelift.
Cheers Al
If it aint broken, you aint trying hard enough
Re: wanted: estate fuel pipe
« Reply #1 on: 28 October 2014, 10:52:46 »
al brown
  • alton, hants
« Reply #2 on: 28 October 2014, 19:59:26 »
Cheers Al,
Don't happen to know what size so you? I did fit a short piece that I had in the garage as a temp measure till I could get the proper pipe but the internal diameter is slightly to big. Didn't measure what size I needed as I planned on getting a proper pipe.
Al
« Reply #3 on: 28 October 2014, 20:14:57 »
5 or 6mm I/D off the top of my head :y
al brown
  • alton, hants
« Reply #4 on: 28 October 2014, 21:41:47 »
Cheers, don't want to get under the car any more times than I need to. Plus it's dark when I get home from work and it's gonna rain. Oh, and I'm lazy too
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #5 on: 28 October 2014, 22:27:45 »
Cheers Al,
Al
Check the inlet /outlet size on the filter
« Reply #6 on: 29 October 2014, 05:48:50 »
Cheers Al,
Al
Aim for a mm less and soak the hose in hot water prior to fitting :y
