Pages: 1 2 [3] 4 5 6 7 8 9   Go Down
Author Topic: Angle Grinders  (Read 29625 times)
0 Members and 4 Guests are viewing this topic.
Re: Angle Grinders
« Reply #30 on: 28 October 2014, 18:10:05 »
Steve, this the bad boy we're talking about? :)
http://www.argos.co.uk/static/Product/partNumber/2378204.htm?CMPID=GS001&_$ja=cgid:18091936165|tsid:59156|cid:189934405|lid:96719256085|nw:g|crid:53116096405|rnd:3937499017770725993|dvc:c|adp:1o1#pdpFullProductInformation
Yep looks the same , dont think ive ever used the handle attachment on mine  ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Angle Grinders
« Reply #31 on: 28 October 2014, 21:29:53 »
Cheers mate. On order!!!  :y
RIP Paul Lovejoy
Re: Angle Grinders
« Reply #32 on: 28 October 2014, 22:00:28 »
I worked with a fella who lost control of a 9" angle grinder when it 'kicked back' when he switched it on.  Apparently it zonked into him at about belt level and cut it's way all up his front and just missed his jugular vein when it cutting his neck apart!  :o :o :o
He had a very impressive scar!  8)  Make sure it has a 'soft start' feature especially for the bigger 9" bad boys!  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Angle Grinders
« Reply #33 on: 28 October 2014, 22:01:41 »
Cheap grinders tend to be larger, noisier and rougher than a 'good' one. I've several from £10 to a £50 Dewalt which is what I'd recommend. But if you're not going to use it much, then a cheapy will do fine.
Do get the thin cutting discs; they cut better and last longer. A grinding disc will last for ages. A backing pad and some 80grit soft discs are well worth having. Don't buy any of this stuff from B&Q etc, as they're blindingly expensive. Trade suppliers or Ebay are best. Ensure that you're buying the right size; 5" discs are no good for a 4.5" grinder unless you're moronic enough to remove the guard!
PPE is necessary, gloves and goggles at all times. Grinders leave a razor sharp burr on sheet metal, which will cut fingers straight down to the bone as I have the scars to prove. Run the grinder along the edge to remove the burr every time you make a cut.
With some practice, a grinder can make decent precise cuts, but your repair panels are still best finished off with snips.
Webby the Bear
  • Northampton
Re: Angle Grinders
« Reply #34 on: 28 October 2014, 22:09:47 »
Nick, thanks for all that info. Don't worry il be wearing a fek king suit of armour as I'm so scared of them.
I'll play  about with it with the disc off to see what sort of kick it gives  :y
RIP Paul Lovejoy
Re: Angle Grinders
« Reply #35 on: 28 October 2014, 22:13:38 »
It won't with no weight on it ::)
Re: Angle Grinders
« Reply #36 on: 28 October 2014, 22:41:44 »
As Al says it won't without a disc and anyway I think any new angle grinder will have the soft start.  :y
I have a £30 Lidl 9" grinder and that does. :y  It's just something to be aware of if you ever borrow one or buy a second hand one!  ;)
Re: Angle Grinders
« Reply #37 on: 29 October 2014, 00:31:18 »
There you go Webby -
http://www.ebay.co.uk/itm/Dark-Authentic-Knight-Suit-Of-Armour-sword-and-stand-185CM-/351134083987?pt=UK_Collectables_Militaria_LE&hash=item51c138eb93
Webby the Bear
  • Northampton
Re: Angle Grinders
« Reply #38 on: 29 October 2014, 09:35:44 »
Hahahaha! cheers mate!
Yes it does have soft start according to the advert.
Presumably thats where it starts off slow and then builds up to full speed.
it arrives tomorrow :)
RIP Paul Lovejoy
Re: Angle Grinders
« Reply #39 on: 29 October 2014, 14:44:52 »
Careful first time , be aware of snagging  :o The correct angle especially grinding so the sparks run away from you and not in your face  :(
Webby the Bear
  • Northampton
Re: Angle Grinders
« Reply #40 on: 29 October 2014, 15:08:44 »
Will be extremely careful mate!!!! thanks for the advice.
RIP Paul Lovejoy
scimmy_man
  • yorkshire
Re: Angle Grinders
« Reply #41 on: 29 October 2014, 15:17:08 »
its been nice knowing you?.........
Webby the Bear
  • Northampton
Re: Angle Grinders
« Reply #42 on: 29 October 2014, 15:24:01 »
 :o :'( :'( :'( :'(
 ;D :y
RIP Paul Lovejoy
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Angle Grinders
« Reply #43 on: 29 October 2014, 15:52:39 »
We were cutting out a rotten section of a land rover chassis years ago and the guard kept getting in the way so my mate removed it. The disc grabbed, shattered and took a chunk out of his wrist. He needed micro surgery to fix the tendons/nerves or whatever it was. Luckily it wasn't his face.
When I was an apprentice toolmaker, we had to endure endless safety videos, but the one I remember most is the grinding wheel safety video. We were shown the importance of safety specs when a wheel lets go and the guy doing the safety course asked if there were any questions, to which my mate asked "what happens if the shrapnel misses your glasses". Clearly this amused us but the seriousness of it is, it would destroy your face.  :o
Having seen a bench grinder let go years ago, and the bits stick in a wall, I've become paranoid about the ring test and wearing full face protection when using my 9"er.  ;) ;D ;D
We all become far too complacent with power tools, just be aware that they don't take prisoners.
Link below is not too graphic but gets the point across. Some are horrific.  :o
 http://youtu.be/eJOiKuVeXA0
Re: Angle Grinders
« Reply #44 on: 29 October 2014, 15:59:59 »
Guard notwithstanding, had he been using the grinder the other way around, ie 180° so the blade was rotating the other way ie cutting down and not up, then the shrapnel wouldn't have hit his face ::)
The guard would also stop him slicing his fingers off...
Good points, well presented though :y
Pages: 1 2 [3] 4 5 6 7 8 9   Go Up
Page created in 0.025 seconds with 20 queries.
