Pages: [1] 2 3  All   Go Down
Author Topic: Gravy wont disappear  (Read 8009 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« on: 29 October 2014, 11:50:34 »
Hi guys  :y
Recently did a cooling system flush and I was on it for almost 2 hours till I had enough.
It was impossible to get the water clear!!!  >:( >:(
When I started, the coolant tank had this...(I know it's bad that's why I went for the flush)
Here is the final colour...
Any thoughts?
Will it ever get clean?
Cheers
Ant
« Last Edit: 29 October 2014, 11:54:48 by Anthony in Madrid »
Still learning...Be nice!
Re: Gravy wont disappear
« Reply #1 on: 29 October 2014, 11:56:31 »
OOOps.. Is that what I think it is? :-\
Have you just replaced the oil cooler?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 29 October 2014, 12:03:41 »
Looks like the oil cooler to me sadly.
If it has gone, the oil tends to collect in the hole were the water pump sites and is a real bastid to remove with normal flushing.
I popped in about 10 Ariel liquid tabs in the water bottle which disolved the oil and flushed it really well  :y
Anthony in Madrid
  • Valencia, Spain
« Reply #3 on: 29 October 2014, 12:04:10 »
No...D'ya think it needs replacing?
Anthony in Madrid
  • Valencia, Spain
« Reply #4 on: 29 October 2014, 12:06:27 »
The oil tends to collect in the hole were the water pump sites and is a real bastid to remove.
I've still got the coolant in the system...Should I re-do it again with "Liquid Tabs"?
If so...How long should I wait till I flush it again after I put in the tabs?
Do you have a step by step of what you did?
Cheers
Ant
« Reply #5 on: 29 October 2014, 12:08:09 »
I think your oil cooler is f**ked.  :-\
This will need to be replaced.........and THEN you flush.
« Last Edit: 29 October 2014, 12:10:37 by Doctor Opti »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 29 October 2014, 12:21:15 »
Cheers
Ant
Quick story for you  :)
I was driving my v6 with a dodgy oil cooler due to money constaints for as few months.
Every 2 weeks or so, i'd just remove the water bottle and clean it out under the tap and refit.
Believe me, after 2 weeks you could remove the mayo with a spoon so don't panic about those traces just yet  :)
Well a few weeks ago, I went for a thrash gentle run down the motoway. The car was running nice and cool until I slowed down to leave the motoway and the block thermostat opened.
Un beknown to me, the radiator had been slowly filling up with mayo and as the stat opened it flooded the engine top end and very nearly cooked the engine (105 degree's / red temp light on) and filling the bottle up with oil in the prosess :'(
Popped in these tabs and drove home slowly.
Within 10 miles, the temp was down to a nice cool 85 degree's and all the mayo had turned into a milk like substance which made flushing it pish easy  :y
Give it a good clean / flush and keep a eye on it but if the oil cooler has gone then get it sorted before the winter sets in  :)
« Reply #7 on: 29 October 2014, 12:25:03 »
Cheers
Ant
Agreed. That cooler looks pretty terminal to me.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 29 October 2014, 12:49:42 »
The washing liquid,emulsifies the the oil. Its how they  clean sea birds etc after an oil spill :y
Hoof'land storeman.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 29 October 2014, 12:52:33 »
Smells nice too  :y ;D ;D
Anthony in Madrid
  • Valencia, Spain
« Reply #10 on: 29 October 2014, 13:04:52 »
Cheers
Ant
Which tabs exactly? I mean dishwasher tabs right?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 29 October 2014, 13:07:13 »
Cheers
Ant
I just used the ones that pop in the washing machine  :y
« Reply #12 on: 29 October 2014, 13:08:38 »
Any washing powder will work AFTER you have replaced the cooler. :y
About twenty flushes should see the water flush clear. :y
« Reply #13 on: 29 October 2014, 13:12:24 »
There's a very effective method for blowing that shit out once it's proper mayonnaise, also involves a box of Aerial Liquitabs, asbestos arms, about 200 litres of water and drive cleaner for afters...
But as said, new oil cooler then worry about cleaning it out. Avoid driving it if at all possible. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #14 on: 29 October 2014, 13:13:19 »
Best to use the liquid on these
Powder tends to foam up were as the liquid just tends to disolve the crap in there  :y
Pages: [1] 2 3  All   Go Up
