Pages: 1 [2] 3  All   Go Down
Author Topic: I'm a bit nervous . . . . VX Main Dealer  (Read 6467 times)
Rog
Re: I'm a bit nervous . . . . VX Main Dealer
« Reply #15 on: 30 October 2014, 22:11:50 »
5.25pm Phone call. Nowt wrong with steering suspension etc. BUT 2 illegal rear tyres. Not what I was expecting. Still doesn't solve the steering vibration or whatever.
« Reply #16 on: 30 October 2014, 22:22:05 »
Hmmm :-\ difficult to judge without seeing it...
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #17 on: 30 October 2014, 22:39:14 »
Could it have throw a balance weight at all? Or may be a problem with new tyre?
« Reply #18 on: 30 October 2014, 22:44:12 »
I thought I'd lost a balance weight on the M3 after a recent track day..
.. turned out all five rear wheel nuts were loose on one side  :-[ :-[
« Reply #19 on: 30 October 2014, 22:44:38 »
Rear geometry can cause the car to crab if the thrust angle is off, and the constant 'correction' in one direction might highlight a weaker balljoint/tre, hence the vibration :-\
Expect the rear tyres to be wearing either centrally or inside edges depending on pressures/loads carried and camber respectively...
« Reply #20 on: 01 November 2014, 09:54:13 »
Not let that gixer fellow near it, that's his trick :P
« Reply #21 on: 01 November 2014, 14:02:09 »
 ;D No, but next time I am adding "check wheel nuts" to my list of post-day tasks.. when I say loose, they were finger tight  :o :-X
Rog
« Reply #22 on: 01 November 2014, 20:10:47 »
So . . . . . . . .
Instructions to garage
1. Vibration at speed. Check and sort it please
2. Spare key knackered, broken inside
3. Locking wheel nut sets sleeve split
4. Tow point cover please
Initial Response
1. No worn joints or anything found, even inspected by their bloke that does MOTs. However, both rear tyres illegal
2. Stock list shows new one in stock
3. Price give for complete new set, sleev not avialble on its own
4. Tow point cover showing in stock but in black
Result
1. New tyres fitted. I had asked for similar to front tyres. Same brand, but not same model. front has Bridgestone Turanza, they fitted Potenza. Not a big deal for me. Car was markedly improved. Vibration gone. Happy  :y
2. Spare key. Disaster time. Was told no reprogramming required. Then told yes it was, they'll do it free. reprogramming failed, blamed on wrong key. End result, no spare key, and the one that used to work doesn't work any more. I have to use the actual key and then start engine ASAP otherwise alarm goes off.
3. Sorted
4. Delay in delivery
Nice bill  :y    :y No charge for checking steering etc. Total £285. Compared with London, cheap. Ok, many here will be shocked, but I'm happy to pay, my car has to work for a living, and off to France next week.
Need to sort the key thing with them though . . . .
Nice people. Compared with other Vx main dealers I've experienced a huge improvement
« Reply #23 on: 01 November 2014, 20:23:27 »
re-sync  :-\ ie key in ignition, press lock ..... car should lock & then unlock = key now re-sync'd  :-\
Rog
« Reply #24 on: 01 November 2014, 23:00:45 »
Just in ignition, or in ignition and turned so all lights on, or in ignition and engine fired . . . . ?
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #25 on: 01 November 2014, 23:07:32 »
Ignition on - all lights on dash.
Drivers door shut (although I'm told this isn't necessary on the Omega)
press lock then press unlock.  Do it a couple of times, just to make sure.
Ignition off and remove key.
Check it whilst sat there and smile when it works.  :y
« Reply #26 on: 01 November 2014, 23:07:59 »
sorry .... ign on so lights are on, but engine off  :y
Rog
« Reply #27 on: 02 November 2014, 11:29:54 »
Nope. Sorry, didn't work. Alarm sounds as soon as door is opened and remote flashes when buttons pressed but does nothing whatsoever with the car.
The guy in the garage was using Tech 2 or something to try and set up the spare key. I think he messed everything up somehow.  :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #28 on: 02 November 2014, 11:41:14 »
Did you get the front tow bar cover ?
Rog
« Reply #29 on: 02 November 2014, 13:51:42 »
No. It showed on their stock list as being available in another branch, but it didn't turn up. They say that it will.
Pages: 1 [2] 3  All   Go Up
