Author Topic: Noisy Fan heater ?  (Read 1840 times)
Noisy Fan heater ?
« on: 31 October 2014, 15:36:30 »
Has anyone noticed how quiet the car is inside with the blower turned off  :-\ Surely it wasnt as noisy as that when new ? Just wondering if the fan needs to come out and be cleaned or lubricated to make it quieter  :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Noisy Fan heater ?
« Reply #1 on: 31 October 2014, 15:42:23 »
Anything that spins will wear the bering out eventually.
Sometimes, bits and bobs can get sucked in past the filter but that's normally a rattle  :-\
« Reply #2 on: 31 October 2014, 18:06:11 »
Certainly the one in the desmond sounds a damn sight healthier than the one in the estate ::)
« Reply #3 on: 31 October 2014, 18:59:05 »
When i turn the fan off its like "wow" !! silence giving your ears a break  :(
steve6367
« Reply #4 on: 31 October 2014, 23:32:28 »
I don't think the climate control is the Omega's crowning glory - I ve never know a system that makes so much noise!
chrisgixer
« Reply #5 on: 31 October 2014, 23:55:41 »
Has it got the latest software for the climate control?
...and yes, one of the first things I commented on was how quiet the fans where in Als 2.2 sport. Suprisingly so actually. Thought mine was quiet, up to then.
« Reply #6 on: 01 November 2014, 01:30:04 »
Yep the Omega's Climate not one of the better ones - although it generally gets the temperatures about right, agreed the fan certainly works hard.  Not apparent on lots of other "climate" cars.
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
« Reply #7 on: 01 November 2014, 06:41:18 »
Fan in my 2.2 very noisey makes all sorts of odd noises but works extremly well and seems powerfull. I quite like the fact that when you do turn it of its like the car is transformed into a rols royce. :y
chrisgixer
« Reply #8 on: 01 November 2014, 13:44:24 »
Yes trouble is, the thing mists up eventually, almost without fail.
« Reply #9 on: 01 November 2014, 14:23:34 »
The FL climate in particular makes the fans a bit anxious.  This doesn't really happen on the PFL, unless the temperature difference is quite wide. Without getting into the PFL v FL debate, the PFL panel does drive the fans more calmly most of the time.
As the OP has a PFL, this makes me think he may have a problem, but obviously would need to hear it to comment....   ....unless with the warm day, if the OPs A/C is BF'd, in which case the thing will be blowing like an old dear after brussels...
