Pages: 1 2 [3]  All   Go Down
Author Topic: Vac leak found. Interesting reason why!  (Read 5340 times)
Diamond Black Geezer
    • & a silly coupe coming...
Re: Vac leak found. Interesting reason why!
« Reply #30 on: 05 November 2014, 12:03:51 »
Just because I'm tired and thick sometimes - where did you fit the halfrauds o-rings? Is that the two pipes that go into the throttle body?  :)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #31 on: 05 November 2014, 12:06:18 »
Correct :)
I played about with the fitment of various sizes and finally selected some ones that were about the same diameter as the OE ones but just slightly thicker :)
RIP Paul Lovejoy
« Reply #32 on: 05 November 2014, 12:22:05 »
Exactly! And no offence taken btw ;)
Thing is if they failed shortly after..... i'd take the ten mins to put them back. no biggy. but the OE ones were not working for me. i replaced them and now i have no vac leak. simplez  :y
The question you need to ask is why weren't the correct o rings working.......as you have addressed the symptom......but what is the cause....  :y
Webby the Bear
  • Northampton
« Reply #33 on: 05 November 2014, 12:26:14 »
Fair point Mark.
I merely put it down to Vx making rubbish parts that need amending ;D
..........i'll get back in my cave with my angle grinder  ;D
RIP Paul Lovejoy
« Reply #34 on: 05 November 2014, 13:05:11 »
Fair point Mark.
 ;D ;D
« Reply #35 on: 05 November 2014, 13:12:25 »
O rings in TB  ??? ??? ???
« Reply #36 on: 05 November 2014, 13:17:01 »
Fair point Mark.
Lol, sadly the engine designers will be considerably better paid, trained, more experienced and qualified than you or I in such design items so they generally get it right. I suspect the V6 engine has been produced in numbers of between 250-500K units and its an issue not been seen before....... ;D :D :y
Do be aware with the setup that the hole in the throttle where the breather bridge tubes go taper in to grip the O rings.
Can you get a pic of the plenum top with throttle assembly fitted and breather bridge removed?
Anyway, where have you been lucky enough to find a cave with power!
Webby the Bear
  • Northampton
« Reply #37 on: 05 November 2014, 14:16:06 »
Oh of course, i completely agree. but ive experienced shite parts from vx before. thats no reflection on the designers i presume.
mines all back together now but i will take a pic when its al apart again.... seems to be apart more often than not  ::)
RIP Paul Lovejoy
« Reply #38 on: 05 November 2014, 14:27:14 »
Yup. Sadly the Accountants will always have an input in the design of anything, even a Bugatti Veyron... (admittedly in that case not much of an input!  :y )
Pages: 1 2 [3]  All   Go Up
