Author Topic: Brake light issue  (Read 2427 times)
nemo
  • Tonbridge Kent
Brake light issue
« on: 01 November 2014, 19:08:38 »
Hi guys I just wondered if anyone has experience of the off side side light coming on when the brake is pushed. Mine is currently doing so,both brake lights work and a brake light warning appears on the dash. Cheers
nemo
  • Tonbridge Kent
Re: Brake light issue
« Reply #1 on: 01 November 2014, 19:10:42 »
Sorry should have said it is the front side light
« Reply #2 on: 01 November 2014, 19:18:45 »
Saloon or estate? Either way be an earthing issue at either the rear light clusters or boot lid wiring depending on which... :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 01 November 2014, 20:47:27 »
+1. Check the loom for breaks witin the rubber trunk near the hinges.
Hoof'land storeman.
« Reply #4 on: 01 November 2014, 21:03:16 »
Most likely be the offside rear light cluster (outer on saloon) or plug :y
nemo
  • Tonbridge Kent
« Reply #5 on: 01 November 2014, 21:29:25 »
Thanks for that will look tomorrow
tidla
  • solihull
« Reply #6 on: 01 November 2014, 21:44:11 »
Before getting in too deep, make sure the bulbs are of the correct type and fitted correctly.
pernix
  • Caerphilly
    • Omega 2.2 dti CD estate
« Reply #7 on: 01 November 2014, 22:05:47 »
check the bulb if its a 2 filament type one of the filaments may have broken and dropped onto the other filament causing a cross of power, had this symptom years ago and had me puzzled for ages
