Omega remapping
Started by Webby the Bear, 01 November 2014, 19:37:10
Quote from: Kevin Wood on 11 November 2014, 12:18:42
Exactly. The physical differences between engines is what makes the biggest difference, namely cams and displacement.
3.0 ECU is a shot in the dark. it might make an improvement, it might make things worse. I wasn't designed for the 2.5 engine in the first place.
Oh, and the fuel pressure on both the 2.5 and 3.0 is 3.0 BAR, by the way. The regulator is the same, as are the injectors.
3.0 ecu works great on my 2.5..  I think both ecus are adaptive but 2.5 map more on the economy side instead of power..
Diamond Black Geezer
Leaving my 2.5 ECU on then!!!  :D
Webby the Bear
Ok then guys.
Let's say for arguments' sake you'd convinced me to go the 3L cams route as opposed to the chip.......
This extra flat spot thats created and fixed with the long plenum..... how bad is it?
RIP Paul Lovejoy
Quote from: Kevin Wood on 11 November 2014, 12:28:59
Quote from: Webby the Bear on 11 November 2014, 12:23:06
Thanks boys.
DBG your explanation makes total sense.
Kev, would you reckon the 3.0 chip would do the same as a superchips chip? or not as the SC chip is designed specifically for the 2.5?
No, the Superchips chip will (hopefully) contain ignition and fuel maps that have been developed for performance rather than the usual mix of emissions, compatibility with all climates and market positioning that the OEM chip was, so that should given you some gains, and those who have tried it confirm this (and that it doesn't seem to impact reliability).
The 3.0 chip is a crapshoot. It's actually likely to have pretty much the same maps as the 2.5 IMHO. Timing might have been tweaked a little, the map might extend to higher MAF output (but this is of no consequence to the 2.5 as it hasn't got big enough lungs to reach it). There is heresay that it improves things, in combination with a load of other mods, but no evidence that the same returns wouldn't have been achieved with the 2.5 chip.
Don't expect stellar results from just a chip in any case.
By far the best modification is a complete 3.0 lump, as has been said.
Fixed :y
Webby the Bear
As mentioned before, amazing results not expected, and if TB is correct then it wont iron out the flat spots anyway.... although others have said different - ill just have to try one i think/
however, before i do..... 3L cams. they cause a flat spot(s) themselves. whats the experience of this?
RIP Paul Lovejoy
Quote from: Taxi Al on 11 November 2014, 16:15:19
Thanks boys.
By far the best modification is a complete 3.0 lump and AR35 gearbox, as has been said.
In fact, sod it.
By far the best modification is a complete 3.0 lump and AR35 gearbox Omega, as has been said.
Fixed :y
Fixed again.
Webby, as has been previously said, you'd be a bit radio rental to buy a Superchips chips for £200-300, when half that will buy you a bigger engine complete with autobox and anything else you want, and this will perform far better, smoother than Superchips attempt (that IMHO wasn't that good).
I wouldn't even bother pissing around with £100 set of G cams. The 3.0l is just the only cost effective option if you want better performance and smoother power.
Webby the Bear
Fair enough jaime.
You mentioned I'd need everything from a 3l.
So block, heads, cams, ECU. Can I not use my old 2.5 plenum, inlets and sandwich plate?
RIP Paul Lovejoy
Quote from: Webby the Bear on 11 November 2014, 19:58:46
Fair enough jaime.
Webby, sincere apologies if this undoubtedly comes out the wrong way, but...
Obtain a COMPLETE 3.0 lump with ancilliaries/wiring/ecu/ar35 from a breaker, (hell you could even buy  cheapy from gumtree or wherever) and fit said COMPLETE lump to Eeyore. If you wish to rebuild it first, then great :y
Stop making everything so complicated for yourself :-*
chrisgixer
Could probably get the complete car with 3.0 attached for not much more money.
chrisgixer
Perfect. Sort the suspension, bin those God awfull wheels, and away you go. :y
Quote from: chrisgixer on 12 November 2014, 00:01:40
That actually looks quite tidy for the old fashioned version :-\
chrisgixer
Quote from: Taxi Al on 12 November 2014, 00:03:28
Oh it's not as superior as the face lift Elite obviously, but needs must and all that.
