Author Topic: Interior trim  (Read 1823 times)
Interior trim
« on: 02 November 2014, 12:02:28 »
How the hell does the side trim come off above the driver right side door to the front screen  :-\ I can see it slides a wee bit but no way will it come off withough snapping something  :( And putting it back on would be impossible me thinks  ::)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Interior trim
« Reply #1 on: 02 November 2014, 14:12:12 »
On the front screen?
Re: Interior trim
« Reply #2 on: 02 November 2014, 14:42:24 »
On the A pillar
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Interior trim
« Reply #3 on: 02 November 2014, 14:57:47 »
Should just pop off. Think the handle above driver should come off. Trim foes from dash to b pillar though
Re: Interior trim
« Reply #4 on: 02 November 2014, 18:17:05 »
Lower B pillar trim, pops off.
Upper B pillar trim, two screws visible at bottom, one at top behind alarm sensor/funny shaped panel.
Then comes away. Leave hanging on upper seat belt bolt.
Drivers grab handle off two hidden screws.
Then from above the door pull the A pillar trim away, working forward until it's free then lift away from the dash/screen end.
Retrieve all the clips stuck in the A pillar and refit to the trim panel...
Bish, bash, bosh :y
Refitting is reverse, but line the trim up by inserting the front, lower corner first then give it a thump to locate the clips in the A pillar. When refitting the B pillar upper trim ensure the belt height adjuster is correctly located and once screwed inplace make sure the door rubbers are correctly located... this also applies to the B pillar lower trim :y
P.S. haven't you done it yet ::) ;D :y
Re: Interior trim
« Reply #5 on: 02 November 2014, 21:07:07 »
Bish, bash, bosh :y
No not been in the car for 3 days  ::) ;D The last time i looked the lower part you mention looked to be plastic welded to the upper part so it has to come off in one piece  :(
I think maybe if the lower part pops off the n i can slide the rest back off the trim hooks  :-\
« Last Edit: 02 November 2014, 21:09:52 by Emd »
Re: Interior trim
« Reply #6 on: 02 November 2014, 23:48:29 »
Nah you've mis read it ::) have a closer look :y
Re: Interior trim
« Reply #7 on: 03 November 2014, 14:36:00 »
All i can see is 2 plastic lugs that are hooked onto metal rings to the frame .. one clip slots one way and other clip slots other way wtf  ??? , been pushing pulling on it and wont come off  >:( I know ill end up snapping it so left it till i calm down  >:( :-[
Re: Interior trim
« Reply #8 on: 03 November 2014, 18:42:25 »
As I typed earlier... ::)
Just pull it off...
Retrieve the clips from the metal A pillar...
Refit clips to the plastic trim...
Refit trim when ready... :y
Don't be tempted to just stuff the wire along the windscreen edge as it will most likely get sliced if the screen ever needs replacing  :-\
Re: Interior trim
« Reply #9 on: 03 November 2014, 19:00:10 »
Just pull it off...
Looks like someone has had a butchers at it already as its hanging off in the middle  :( Shil have a look more closer  :-[
Re: Interior trim
« Reply #10 on: 03 November 2014, 19:06:45 »
Iirc there are 3 clips :y
