Author Topic: engine change on my V6 - anyone recommended (South East)  (Read 7181 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: engine change on my V6 - anyone recommended (South East)
« Reply #15 on: 05 November 2014, 14:26:03 »
That is going some, Mark! It'd take me that to change plugs  ;D
On a serious note.... what would be your rough plan of attack for doing it....?
RIP Paul Lovejoy
serek
  • huntingdon
    • 3.2 mv6
« Reply #16 on: 05 November 2014, 15:30:12 »
You can pop an Omega engine out in circa 2 hours with the box still attachéd
ones round RobG we menage to pull engine with gearbox out just under an hour :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #17 on: 05 November 2014, 16:45:21 »
Anyone fancy doing an engine swop for me, I'm in Guildford/Woking and can drive short distance from there, have complete engine to go in place of knackered one, needs doing before xmas.
if you wont find anyone local,  I can replace engine on your car
Im about 100 miles from you but if you dont want travel I can pick car up and drop off :y
I would recommend that you accept Serek's offer; even if you choose to travel to him it will be well worth the journey......
Ron.
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #18 on: 05 November 2014, 17:18:14 »
Get in touch with Serek. You won't regret it and the job will be done well.  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #19 on: 05 November 2014, 17:42:55 »
You I can pop an Omega engine out in circa 2 hours with the box still attachéd
Fixed that for you Mark. :y
« Reply #20 on: 06 November 2014, 13:41:48 »
The thing to remember is that the Omega power units are plug n play.
So all the engine wiring loom goes to multiway plugs which you disconnect.
Then disconnect the main power cables.
Drop the prop shaft and associated linkages off the box.
Disconnect fuel and water pipes (from bulk head fast fit connectors and rad).
Remove bag pipes.
Disconnect front pipes and remove.
Disconnect vac pipes and remove main brake servo pipe.
Scuttle off
Disconnect aircon pipes at the quick connect couplings.
unbolt engine mount (one end only)
Check for other odds n sods (version dependent such as air injection etc).
Lift and out it comes.
« Reply #21 on: 06 November 2014, 13:47:29 »
Can probably do it in about half an hour if you don't want to reuse the shell ;D
Webby the Bear
  • Northampton
« Reply #22 on: 06 November 2014, 14:15:10 »
Nice one Mark  :y
RIP Paul Lovejoy
omega squared
  • london area
    • 335i/race car/2 x V6 est
« Reply #23 on: 06 November 2014, 15:43:17 »
thanks for the replies so far looks like no one local then, will PM Serek.
cheers
nothing tows better than an Omega estate in this price range
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #24 on: 06 November 2014, 15:52:45 »
cheers
he is your best bet tbh. otherwise it means traveling.  :y
