Author Topic: Faulty Thermostat Signs  (Read 2780 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« on: 05 November 2014, 17:51:15 »
Hi Everyone
Hope your day is going well.
Have been advised to change the thermostat whilst changing the oil cooler as I have access to it during.
My question is...
What are the symptoms of a faulty thermostat?
Cheers
Ant
Still learning...Be nice!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Faulty Thermostat Signs
« Reply #1 on: 05 November 2014, 17:59:23 »
Low temp, heats up whilst stuck in traffic, cools down again on a run.
« Reply #2 on: 05 November 2014, 18:00:06 »
My question is...
Cheers
Ant
Generally the engine doesn't get up to full working temp and it's slow to get to its max temp ie the 'stat is stuck open. If it was stuck shut, you'd know about it as the car would continually over heat.  ;)
« Reply #3 on: 05 November 2014, 18:09:42 »
Will the heater be cooler on full heat .. ie not hot enough  :-\ Just asking as i was about to ask the same thing and my heater wont get burning hot  :(
tidla
  • solihull
« Reply #4 on: 05 November 2014, 18:30:56 »
I fitted a thermostat, "because i was in there" removing a gm item and fitting a qh brand. wish i hadnt as after 12 months it stuck shut and nearly fried my block.
sjr47
« Reply #5 on: 05 November 2014, 18:57:59 »
Yep, came back up M5 from Bristol one cold night last year temp never went above 82oC heater useless nearly froze screen up changed stat ASAP lovely n warm again.
« Last Edit: 05 November 2014, 18:59:37 by sjr47 »
« Reply #6 on: 05 November 2014, 19:14:02 »
Time to confront the Bs'd bolt then  :(
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 05 November 2014, 21:03:53 »
Don't cross thread the b bolt. I repeat. Don't cross thread it.  ::)
RIP Paul Lovejoy
« Reply #8 on: 05 November 2014, 21:51:04 »
I think it took an hour or so to home the bolt last time  ::)
sjr47
« Reply #9 on: 05 November 2014, 23:22:37 »
Ah memories did mine when temp was close to freezing !! upside being you don,t feel the skinned knuckles till later, ended up ditching the lifting bracket and fitted a horseshoe. shaped washer to infill after locating bolt :'( :'(
« Last Edit: 05 November 2014, 23:27:43 by sjr47 »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #10 on: 05 November 2014, 23:24:09 »
Lovely hot air from the vents in mine Mr EMD.  :P
Webby the Bear
  • Northampton
« Reply #11 on: 06 November 2014, 07:59:29 »
As to the original question.  .  .
If your cars not getting up to temperature, start the car from cold and keep yr hand on the top hose. If it gets warm / hot quickly then you know the stat is opening too soon.  :y
RIP Paul Lovejoy
