Author Topic: P0420 fault code  (Read 4065 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
P0420 fault code
« on: 06 November 2014, 10:35:47 »
Engine light is on and following codes are flashing
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
I have a leak between the mid exhaust box and the back box could this effect the above codes?
www.impactcls.co.uk - Flight Case Manufacture
Re: P0420 fault code
« Reply #1 on: 06 November 2014, 10:38:59 »
Nope, pre-cats are getting tired.
The fix is to relocate the second O2 sensor to behind the main cat
Impact Pete
  • Derby
« Reply #2 on: 06 November 2014, 10:41:50 »
ok so just a coincidence then with the leak ive had a few weeks.
re moving sensor will the engine light clear after the set amount of clean starts or will it need clearing?
« Reply #3 on: 06 November 2014, 10:52:15 »
It will clear it self
I might be able to spare an hour and fit new bosses for you if needed
Impact Pete
  • Derby
« Reply #4 on: 06 November 2014, 19:05:10 »
hi very kind will get back to you once I get to have a proper look
thank you
Impact Pete
  • Derby
« Reply #5 on: 15 November 2014, 14:11:44 »
Thought I would update that the engine light went out a few days later so decided not to do anything!
    • 530D M Sport, 330i Coupe
« Reply #6 on: 15 November 2014, 14:16:54 »
It'll come back on again more and more!
chrisgixer
« Reply #7 on: 15 November 2014, 16:52:04 »
Pre cats will get more and more tired as the miles roll by. So the light will stay on for longer and longer periods. Until it's on permenamtly.
Keeping them hot is key, to a point. So lots of pootling in traffic will usually see the light on more often than a motorway journey. And more in turn than ragging the t*ts off it.
What ever you do though, do NOT be tempted to replace the enire cat. See the guide on a permenant fix, muuuuch cheaper. :y
Impact Pete
  • Derby
« Reply #8 on: 08 May 2015, 20:07:35 »
I thought I would update on this as it's now May and the lights still off and the codes are clear  ::)
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #9 on: 08 May 2015, 20:14:13 »
Give it time. :)
Impact Pete
  • Derby
« Reply #10 on: 08 May 2015, 20:17:11 »
Give it time. :)
6 months is time oh all yee of little faith, this is not the first time an issue has disappeared on my omega without any maintainance!  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #11 on: 08 May 2015, 20:40:38 »
Might be worth giving it the shell Italian tune up. :y
Hoof'land storeman.
The Sheriff
« Reply #12 on: 08 May 2015, 20:43:01 »
Bulb's gone. ;D
« Reply #13 on: 08 May 2015, 21:03:06 »
Bulb's gone. ;D
Ne'er a truer word said in jest... ::)
Impact Pete
  • Derby
« Reply #14 on: 08 May 2015, 21:04:59 »
Bulb's gone. ;D
wouldn't stop codes showing though  :)
