Author Topic: Does concentric clutch slave cylinder have moving seals?  (Read 2540 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 08 November 2014, 14:32:24 »
Chatting to chums in the pub last night I mentioned that the Omega has a concentric clutch slave cylinder. Rubbish, they said, that would need two concentric seals, hard way of doing it. I saw their point, but still reckonned it was concentric. Today, looking at my photographs, I wonder if it has any moving seals, or if it simply 'swells' when hydraulic pressure is applied.  Please enlighten me.
sjr47
Re: Does concentric clutch slave cylinder have moving seals?
« Reply #1 on: 08 November 2014, 15:47:16 »
Would think they work like brake caliper cylinders they have to be self adjusting to take up wear in clutch just like brakes therefore being single action only just moving off clutch when hydraulic pressure is released.
« Last Edit: 08 November 2014, 15:50:10 by sjr47 »
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 08 November 2014, 15:52:04 »
Good thinking, sjr47. So it cannot be a simple swelling cylinder, can it?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 08 November 2014, 15:52:14 »
It's concentric around the gearbox input shaft.
Doing it that way has the advantage of not needing an actuating arm and separate pivot.
It has the disadvantage of having to remove the gearbox when the thing fails. And I don't think they're that much more reliable than an external cylinder.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 08 November 2014, 16:44:11 »
In 1977 in a Peugeot 505 family estate I had the wretched lever arm crack and the clutch failed. I had to drive the car back from Wallingford to Midsomer Norton - 70 miles - carrying 6 elderly relations without a clutch, pulling away on the starter.
My original question was - how do you make a concentric clutch slave cylinder? If it is a piston in a cylinder, it will need two seals, whre one would have done in a simple cylinder.
« Reply #5 on: 08 November 2014, 21:14:12 »
It's a piston with a hole punched through it - so it's a donut with twice as many seals..
Patent drawings: http://www.google.com/patents/US6374724
« Reply #6 on: 08 November 2014, 21:43:16 »
First imagined in 1983 apparently  :y
  • Auckland
    • Mazda MPV
« Reply #7 on: 08 November 2014, 21:46:00 »
That patent appears to show a design that allows one seal to bridge the gap between inner and outer cylinder walls.
The concentric slave cylinder is an elegant design solution. It has one moving part, is self adjusting and avoids applying sideways loads to the release bearing.
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 08 November 2014, 22:04:13 »
Thank you gentlemen, and congratulations. My friends were right, it has two seals. I was right, the slave cylinder is indeed concentric. It is a recent invention, and quite tricky to manufacture.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 08 November 2014, 22:43:54 »
Thanks Andy. I have read the patent a couple of times, and studied the drawings, but cannot decide whether there are two seals, or one seal spanning both sides of the narrow annular chamber. One would certainly be more elegant.
« Reply #10 on: 10 November 2014, 13:44:58 »
On the Omega setup there is two hydraulic seals plus a bellows type dust seal, cant see them being that hard to manufacture.
And failure of them is all but unheard.
