Author Topic: My Turn For a Fault  (Read 2431 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
My Turn For a Fault
« on: 08 November 2014, 22:32:39 »
Just been shops With two heated seats on.Rear window heater on.. lights on and fan blowing full blast.
Noticed the Batt light on the dash was on. It was very dim, And when i took the load off it, Then it went all the way out.
Had new battery in the summer, So my first thoughts.(well only thought) is that the rectifier/diodes ETC in the Alternator Are ready to call it a day.
But then the load the electrics were under was a lot.
Sitting in the garage is a ready to go alternator from omegod bought 6 months ago from that 2.2 he broke..
Do you think i will be unwrapping that for xmas  :-\
flyer 0712
Re: My Turn For a Fault
« Reply #1 on: 08 November 2014, 22:36:34 »
Do it now before it gets too cold  :y :y
« Reply #2 on: 08 November 2014, 22:43:50 »
Is the +ve to the battery hot/warm? It could be the crimped connector that's iffy. My mfl did the same but I managed to borrow a heavy duty sized crimper from work & tightened the joint a bit. It sorted the dim lamp!  :y :y
Steve B
  • Leicestershire
« Reply #3 on: 08 November 2014, 23:04:48 »
ita already cold  ;D ;D ;D
Steve B
  • Leicestershire
« Reply #4 on: 08 November 2014, 23:05:36 »
Gonna have a look tomo andy.
« Reply #5 on: 08 November 2014, 23:06:59 »
Put a jumper on & go and check it now while it could still be warm .......  ::) ::)
steve6367
« Reply #6 on: 09 November 2014, 08:10:32 »
Second that - just had that exact problem on my 2.2.
« Reply #7 on: 09 November 2014, 18:40:49 »
Indeed. First things first. Check all the connections between engine, battery and chassis ground.
Steve B
  • Leicestershire
« Reply #8 on: 09 November 2014, 20:18:42 »
Went out on say half a mile drive and then stopped car and got my hands around battery terminal connection like Andyb said.
Though they were not hot, They were both Definitely warm,With like that dry crud stuff around the + connector, So tomorrow i will have them off and give them a good clean up and re Crimp Them.
While under the bonnet decided to get the volt meter across the battery .
Engine off....         12.7 volts
Engine ticking over 14.3 volts
Q When parked say 4 feet in front of garage door with car ticking over... When i rev the car, Should headlights get brighter  :-\
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #9 on: 09 November 2014, 20:35:29 »
Halogens will always react a little.  It shouldn't be a significant change though.
« Reply #10 on: 09 November 2014, 23:35:11 »
When I had an alternator go on a 2.0L the light went bright then out and the speedo stopped working, iirc.............. ;)
