front screen misting up
Started by farmer andy, 14 November 2014, 16:50:21
Broomies Mate
Quote from: Toledodude1973 on 14 November 2014, 21:48:28
Only trying to help!
Sorry, didn't mean to offend.  Just thought you should know that when the A/C compressor isn't functioning, it is in ECO mode.  :y
If you are just short on gas, get it sorted.  The A/C should be run for a minimum of an hour a month, although I thranslate that to an hour a week.
If your system is knackered (faulty compressor/condenser) then don't worry about it (if you don't want it fixed, that is);.
As an aside, are you sure its a 2.5DTI, as Vauxhall never released such a car (only Opel). If its a Vauxhall, but pre approx 2001, it will be a 2.5TD, and if a Vauxhall post approx. 2001, it will be a 2.2DTI.  There are pretty major differences between these various engine types ;)
Back to your issue, misting up is obviously caused by moisture in the cabin - hardly surprising this time of year, added to the fact that the Omega doesn't have the best ventilation in the world.
Reasons it can happen are anything from getting in with wet coats etc, A/C suddenly stop working or water entering the cabin.
Some pointers to check:
Is the AC working (AC acts as a dehumidifyer, but when turned off, and lot of the recent condensate re enters the cabin)?
Is the passenger footwell carpet wet - if so check scuttle drain is clear.
Is the pollen filter wet or missing (damp ones can be dried out).
Is the correct pollen filter fitted if a facelift car (non carbonised ones on facelifts can cause recirc function to come on automatically)
Is recirc on
Is the outside temp, according to temp gauge dipping below 4C (thus AC system shuts down)
Check the ventilation exhaust vents (OS rear cubby hole in boot) are clear, and not stuffed with rags/blankets/shite, as this stops/reduces airflow entering the car, as it can't effectively exhaust.
Leaks around sunroof (rare on Omega) or split doorseals (rare on Omega)
If its just a load of wet people got in together, and its too cold for the AC to work (4C), just doing a few miles with the rear windows open by about an inch, and heaters on pointing to floor (and windscreen if required), can do wonders to help remove the excess moisture quickly...  ...and if that works, revisit the exhaust vents for restrictions ;)
chrisgixer
This time of year I do find General de misting first thing to be a nuisance. Cold air from de mist function doesn't work, until some heat gets into the cooling system and all is well. Usually just as the lpg flicks over, which makes sense.
I don't hink there is anything wrong as such, it's just slow to warm up.
...although obviously the op has further issues. Get that ac sorted, only then will the climate control function as designed. It WILL steam up with ac off (Eco on) this time of year, regardless.
