Author Topic: Recommendation for head gasket change  (Read 7122 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
« on: 20 November 2014, 14:35:15 »
Hi all,
I am looking for a recommendation for someone on here to do a head gasket change on my Omega 2.5V6.
I have stripped the car down as a start, but would like someone experienced in working on the V6 to complete the job properly, as I don't really have the available time to complete the job before xmas  :(
The cam belt, cam belt covers, sprockets etc are all off. I have all the parts including a full head gasket set (including cam cover gaskets etc), new bolts, water pump, thermostat....
Any help much appreciated!
Thanks
Stu
Take a look at my Dog Training blog at Dog Training HQ
Re: Recommendation for head gasket change
« Reply #1 on: 20 November 2014, 18:22:22 »
What were the symptoms to lead you to think it's failed?
Are the heads now off? Given the dark nights do you have a garage / lighting?
« Reply #2 on: 20 November 2014, 19:21:15 »
I'd try Darth Loo-knee given your location. Top bloke, though with a dubious taste in 1980s Pop music
« Reply #3 on: 20 November 2014, 19:28:51 »
I'd agree with the above :y
If you get stuck I may be able to help, but with my shift work / family life my times quite limited these days.
Still interested in how it's failed :y
stuvaux
    • Dog Training HQ
« Reply #4 on: 20 November 2014, 20:05:26 »
Thanks for the info  :y
The symptoms have been a water leak that has slowly got worse over time. I have used K-seal a couple of times too  :-[
The engine is now stripped down to the heads (heads not off though), and there is clearly some K-seal that has tried to seal the head gasket leak....
I do not have garage access or lighting really so daylight time only really plus weather dependant  :-\
Is it best to PM Darth Loo-knee? I actually quite like 80's music too..... ;D
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 20 November 2014, 21:41:56 »
Oh no.  I suspect you have acted in haste!  :'(
stuvaux
    • Dog Training HQ
« Reply #6 on: 20 November 2014, 23:03:56 »
In what way?  :-\
sjr47
« Reply #7 on: 20 November 2014, 23:12:20 »
Could well of acted in haste possible oil cooler leak or HBV  9 times out of 10 if its one of the items removed get it pressure checked B4 you go any further.
« Last Edit: 20 November 2014, 23:15:06 by sjr47 »
stuvaux
    • Dog Training HQ
« Reply #8 on: 20 November 2014, 23:20:42 »
Now it is stripped you can clearly see where the K-seal "attempted" to seal the leak, coming from the gasket join.....
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #9 on: 21 November 2014, 07:32:02 »
I also have the same problem.. But its not the HBV , oil cooler or and hoses.... Fingers pointing to core plug or head gasket.. I also used an additive to stop coolant leak and I worked a treat but its clogged Mt matrix up and heating inside car is really poor. :(
stuvaux
    • Dog Training HQ
« Reply #10 on: 21 November 2014, 09:15:49 »
Yes my matrix got blocked after using K-seal, and then started leaking so had to change it.
vauxsull
    • 3.0 Elite
« Reply #11 on: 21 November 2014, 09:28:23 »
If my matrix starts to leak the car is going to get cubed and sent to china to be made into a fridge.
stuvaux
    • Dog Training HQ
« Reply #12 on: 21 November 2014, 12:55:33 »
It's not that hard a job if u follow the cheat method on here....it does mean cutting away a small part of the dash tho, but isn't noticeable afterwards  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #13 on: 21 November 2014, 12:58:10 »
true, done about 4 or 5 of them.  ;)
« Reply #14 on: 21 November 2014, 13:02:26 »
Hardest part is carefully peeling back the covering without tearing it, and then not shredding it as you proceed to hack bloody great chunks out of the dash with a Dremel ::)
Undoing/refitting the bolt for the pipe join is a bit of a fiddle, but a satisfying job all told :y
