Author Topic: windows misting up  (Read 5892 times)
slowboy
  • lode
Re: windows misting up
« Reply #15 on: 24 November 2014, 14:46:51 »
had same problem.as last resort changed carbon filter .cured
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #16 on: 24 November 2014, 20:18:52 »
Is a carbon filter the same  as a pollen filter or does it go somewhere different?
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
« Reply #17 on: 24 November 2014, 20:34:06 »
Goes in the same place :y
Toledodude1973
  • IPSWICH U.K.
« Reply #18 on: 24 November 2014, 20:46:48 »
is a carbon one better than pollen AL?
« Reply #19 on: 24 November 2014, 20:58:34 »
Yes and no...
Carbon filter is required for any pre/mid facelift cars with Electronic Climate Control and ALL facelifts :y
A standard pollen filter will do exactly what it says on the tin if fitted to a facelift, but the system is designed to work with the carbon filter :y
Toledodude1973
  • IPSWICH U.K.
« Reply #20 on: 24 November 2014, 21:06:50 »
Thanks Al, ask and you learn :y
farmer andy
  • carlisle
    • 2.5tdi saloon
« Reply #21 on: 27 November 2014, 17:01:32 »
thanks to all who replied to my problem. Ive done everything now except put in a carbon filter, so that is my next move and hopefully it will cure the problem. If not ive ordered a 12v dehumidifier online.
Whilst im here, whenever I disconnect my battery, I cannot reset the clock time and date. Then after a while it does it on its own to the right time and date. Totally baffled by this.
« Reply #22 on: 27 November 2014, 17:09:23 »
It's supposed to do that, it uses the RDS signal. It is possible to turn the RDS off ..... really can't remember now ..... for when you might want to set the time to Frence time etc  :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #23 on: 27 November 2014, 17:30:14 »
Where`s that then???  ;D
« Reply #24 on: 27 November 2014, 18:17:56 »
Near Franch  ;) ;)
Page created in 0.237 seconds with 20 queries.
