Author Topic: C25XE vs X25XE Tuning chip  (Read 5573 times)
Rifai
  • UAE
    • Omega B 1997
« on: 22 November 2014, 16:15:19 »
A question to the experts here:
I have a X25XE fitted on omega 97. I intent to buy a performance chip for my engine from ebay.
the German guy listed the chip under C25XE, according to him the chip will work on my X25XE with no issues at all. is that true? I don't want to lose my engine  :'(. what bad could possible happen if it's the wrong chip?
Thanks for your help.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: C25XE vs X25XE Tuning chip
« Reply #1 on: 22 November 2014, 16:27:03 »
Depends whether the Maps are the same, the answer which I dont know, wouldn't have thought they would be much different.
I assume you already know the best way to get more power out is to fit 3.0 Cam setup.
A lot of discussion here from about a week or so ago (12 pages in fact). - http://www.omegaowners.com/forum/index.php?topic=127038.0
« Reply #2 on: 22 November 2014, 18:32:38 »
As the C25XE was never fitted to the Omega, I suspect it won't be an ideal map for the car...  ...and that's before you get to things like the ECU controlled multiram setup that wasn't fitted (I believe) to the Chavalier etc.
I'd also avoid all chips from the likes of egay.
Rifai
  • UAE
    • Omega B 1997
« Reply #3 on: 23 November 2014, 00:56:25 »
Well, I ordered it. I will give it a shot.
if it doesnt work for me I will return it at once.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 23 November 2014, 01:05:03 »
You are right.  The inlet is completely different to the Omega.  No Multi-Ram setup for starters.
That map will be a massive hindrance to the Omega.
Rifai
  • UAE
    • Omega B 1997
« Reply #5 on: 25 November 2014, 10:13:47 »
I bought the chip. I will give it a try and post the result if you are interested
zirk
  • Epping Forest
« Reply #6 on: 25 November 2014, 10:20:52 »
Yep.
Muroman
  • Finland
  • Cars for life
    • Vectra -02
« Reply #7 on: 25 November 2014, 12:39:22 »
Yes, post the results!
Driving: Vectra - 2002 - 2.2 "GTS" - Manual
Old: Omega - 1999 - MV6 - Automatic
Old: Omega - 1995 - MV6 - Manual
hawke113a
  • leeds
« Reply #8 on: 03 December 2014, 22:11:18 »
call me mr thicko but if i fit the 3.0 cams to my 2.5 ill have more power....is it just a straight swap or do i have to cahnge anything else other than the cam shafts.(not totally up on engine mods)....im having a rebuild at the min and while engine is in pieces i might as well upgrade it
zirk
  • Epping Forest
« Reply #9 on: 03 December 2014, 22:29:02 »
Yep, Cams and the Inlet Divider for a 3.0.
