Author Topic: Wipers  (Read 2827 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
Wipers
« on: 23 November 2014, 18:04:56 »
Noticed today my wipers are stopping at least 4 inches above their normal park level. If on set speed they function normally, if on intermittent they stop 4in above park level, then when triggered instead of going from that position, they drop back the 4ins then sweep ???  And whole process repeats itself. Now I have to resort switching to set speed, then quickly turn off ignition to park them correctly. Regardless if I now switch wiper stalk to off, as soon as the ignition is powered up, yes you guessed it, they automatically move from park to out of position and it's Bloody Annoying :( any thoughts chaps, seems more Electronic than Mechanical :y
Re: Wipers
« Reply #1 on: 23 November 2014, 18:08:35 »
..... any thoughts chaps, seems more Electronic than Mechanical :y
Mechanical ..... http://www.omegaowners.com/forum/index.php?topic=117001.0  :y
Usual cause is not clearing snow &/or ice from the screen before turning the wipers on  ::) ::)
tooleater
Re: Wipers
« Reply #2 on: 23 November 2014, 18:24:05 »
Thanks for that Andy, never do that mate and have we actually had Winter in the last couple of year ;D. The Link, not sure whether to say cheers or you've got to be kidding :y
Re: Wipers
« Reply #3 on: 23 November 2014, 18:34:13 »
It's easy! There are only 4 hex headed self tappers holding it all in place. Just be very careful when you lift the assembly over the driver's side wing otherwise you'll damage the paint ..... maybe a thick piece of card to protect it. Nothing that you couldn't easily do in an afternoon.  :y :y
You might need a wiper arm removal tool too, the arms sometimes get quite attached to the splined drive spindles ...... nothing that a wiggle won't sort out though.  ::)
« Last Edit: 23 November 2014, 18:36:22 by Andy B »
chrisgixer
Re: Wipers
« Reply #4 on: 23 November 2014, 21:27:00 »
Might want to remove the scuttle as well Andy B. ::)
Re: Wipers
« Reply #5 on: 24 November 2014, 04:47:14 »
Ideally the fix is a lot easier with linkage/motor removed from car, (wipers & scuttle off, multi-plug & 4 hex fixings holding linkage)
as per the instructions on the link ..........
chrisgixer
Re: Wipers
« Reply #6 on: 24 November 2014, 08:36:25 »
Which I would say is not particularly easy for most people. :)
....with a good chance of scratching the wing when removing the wiper mechanism. Btw.
Doable though. :)
Re: Wipers
« Reply #7 on: 24 November 2014, 08:41:04 »
Doable though. :)
Hence my warning ............  ???
chrisgixer
Re: Wipers
« Reply #8 on: 24 November 2014, 09:03:59 »
And mine..... ???
If it's ok with Andy B of course. ::)
Re: Wipers
« Reply #9 on: 26 November 2014, 00:39:49 »
Just removed scuttle, and adjusted position in situ on the Estate - no need to remove wiper mechanism ;)
