Author Topic: Should this be allowed ??  (Read 10212 times)
Re: Should this be allowed ??
« Reply #30 on: 29 November 2014, 19:40:27 »
nope..
and the effect of those bolts on flow is really negligible compared to total area..  because the backing metal horizontal surface is bigger
So you are saying there is an effect on air-flow.
So, you are agreeing with me, whilst being a pedant.
Ner ner ner ner ner!  ;D
every shape change on the flow path of a fluid will effect its flow obviously.. however, those calculations are tedious and complex so some simulators or a wind tunnel model is used mostly.. so , its not that easy to look and have a guess at flow types..  ::)
chrisgixer
« Reply #31 on: 29 November 2014, 19:49:07 »
Broomies Mate
  • Bristol, UK
    • Stuff!
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #33 on: 29 November 2014, 19:51:41 »
Has anyone else read David Vizard's book on tuning Mini engines? He flow tested a 1.5"SU carb with just those modifications in the diagram, and gained nearly 10cfm, from a starting point of 143cfm which is a sizable improvement for such a simple mod. Threadlock on the screws was recommended!
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #34 on: 29 November 2014, 19:52:53 »
Must be a load of bollards.... Cem said so.
chrisgixer
« Reply #35 on: 29 November 2014, 19:56:47 »
As was added to the guide on here iirc. :)
« Reply #36 on: 29 November 2014, 20:00:46 »
Cem said dont guess at complex subjects  ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #37 on: 29 November 2014, 20:02:50 »
It's not complex, Cem.... is bloody obvious.
BM says stop being a complete twunt, there's a good lad.  :y
« Reply #38 on: 29 November 2014, 20:11:23 »
not.. you dont have any of those coeffcients let alone any calculations based on air flow at any rpm range
The Sheriff
« Reply #39 on: 29 November 2014, 20:15:20 »
Just buy a car, after a test drive, of course, take it home and use it. Don't fiddle with it's screws or owt, just drive it. If you want a faster car, buy one. :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #40 on: 29 November 2014, 20:23:32 »
Pains me to say it but thats quite sensible advice :-X ;)
other rides
« Reply #41 on: 29 November 2014, 22:15:29 »
 ;) :D :D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #42 on: 29 November 2014, 23:06:08 »
 ;) :D :D
Wise words indeed from the experienced famous Daewoo owner   ::) ;D :y
chrisgixer
« Reply #43 on: 29 November 2014, 23:33:18 »
...and service it.  :-X
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #44 on: 30 November 2014, 18:16:42 »
We started with Tyre threads.
To winter tyre threads.
To cam cover gasket threads.
To fekkin TB screw threads. Wtf  ;D ;D ;D ;D
RIP Paul Lovejoy
Pages: 1 2 [3] 4  All   Go Up
