Author Topic: Self levelling suspension.  (Read 2056 times)
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« on: 29 November 2014, 10:32:14 »
I have pulled the fuse to stop the above working,  as it just keeps getting higher and higher. Which relay is it that runs it. As my daughter wants the rear 12v supply working and it's on the same fuse. Thanks
Re: Self levelling suspension.
« Reply #1 on: 29 November 2014, 10:53:49 »
It's in the panel next to the cabin fuse box. Left hand one, main beam, S/L other one. Both the same
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #2 on: 29 November 2014, 16:44:39 »
Have you checked the sensor on the rear suspension? The little arm from the sensor can pop off. Then the self levelling wont know when to stop?
« Reply #3 on: 29 November 2014, 17:04:29 »
Connects to the right hand rear suspension arm near the diff :y
chrisgixer
« Reply #4 on: 29 November 2014, 17:08:37 »
Fuse box under steering wheel top left(?iirc) small black one of two. Tother is main beam so if that still works you have the right one.
But be advised, while SL socks are still fitted, the bladders will chafe themselves to bits in fairly short order, if not inflated. If it gets that far.
Does it just keep rising to full height non stop? Or does it build up over a a week or two ?
