Pages: 1 [2] 3  All   Go Down
Author Topic: wheel and brake wobble  (Read 10623 times)
flyer 0712
Re: wheel and brake wobble
« Reply #15 on: 02 December 2014, 00:05:37 »
Just interested....seth...if by bleeding the system may cause it to work ok for a while and then it  starts to do it again,,,,what would be wrong with the master cylinder to make it do that..thanks  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #16 on: 02 December 2014, 08:32:50 »
no lips on discs as they are new,,,,,,they were changed because of this problem but it remains....however will tell him to check the the new discs just in case   thanks   :y :y
Just for reference, I drove my shed for 6 months on knackered front discs (large ridge / corrosion causing heavy vibration when braking hard / brakes quite hot)
Changed the discs and pads for genuine parts last month because of these symptoms but the fault remained.
Noticed that the tracking was slightly out but I was not to worried as I would need replacement tyres soon and I wanted to replace the shocks all around anyway (when funds allow)
I noticed last week the tracking was getting worse so popped into the local tyre place for a tracking check on the understanding that I could get under there with a bar first to see if they was and play in any joints.
Checked the joints, no problem.
Jacked it up and checked for wobble on the wheel.
Put it this way, I have big gonads when it comes to most things but I drove the car home at 15 mph with the hazards on and parked up.
The car hasn't move since  ;)
Oh yeh, It went through a MOT during the 1st week of September  :(
Basically, the wheel went from "a little vibration when braking heavy / hot" too "a totally collapsed bearing" in about 3 weeks  ;) ;)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #17 on: 02 December 2014, 08:38:46 »
What are the rear discs like?
flyer 0712
« Reply #18 on: 02 December 2014, 10:27:24 »
To be honest the rear discs and pads look to be ok with no lips on discs and pads half worn,,but did not check them for being warped...thats next on his list now, :y
chrisgixer
« Reply #19 on: 02 December 2014, 11:41:11 »
If the discs where warped, or incorrectly seated, or out of true in any way,  you'd feel inconsistent brake force the slower the speed when braking. So in effect you'd be nodding your head as you pull up at the lights etc.
  • Online Online
« Reply #20 on: 02 December 2014, 12:36:34 »
I may have this problem.
Front discs and pads have covered over 30,000 miles.
« Reply #21 on: 02 December 2014, 12:40:27 »
Brakes very, very rarely "warp" ... think of it .. the disc is pretty thick and robust ... just how does it warp so easily as people make out ??
The answer .. it doesn't !
http://www.powerbrake.co.za/tech_info/tech_01_judder.htm
http://www.powerbrake.co.za/tech_info/tech_03_warping.htm
« Reply #22 on: 02 December 2014, 12:55:39 »
Not allowing for heat dissipation, or lack of, holding the brakes on after working them hard... ::)
« Reply #23 on: 02 December 2014, 14:01:31 »
yup ... primary causes of DTV .. not warping ...  blame Cementite ....  :)
« Reply #24 on: 02 December 2014, 18:36:35 »
and using cheap pattern discs  ::)
  • Online Online
« Reply #25 on: 02 December 2014, 18:46:40 »
I hope my replacement £88 Pagid discs and pads come come under this description?.. :-\
« Reply #26 on: 02 December 2014, 19:09:29 »
the cheap pattern discs for the front of my Senator 24 valve were included  >:(
« Reply #27 on: 02 December 2014, 19:24:58 »
Whatever Devon and Cornwall Constabulary had endowed it with before I bought it ::)
flyer 0712
« Reply #28 on: 02 December 2014, 19:55:14 »
That write up is very interesting reading....what appears to be a simple subject...brake judder....turns out to be a very deep and complicated issue...However  after reading the explanation that has been posted,it does help to not only disperse (old wives tales ) but also to under stand the issue properly,, :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #29 on: 03 December 2014, 12:10:43 »
'Cadence braking' ... as practised by train drivers 8)
Pages: 1 [2] 3  All   Go Up
