Author Topic: outside temperature sensor  (Read 2590 times)
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« on: 04 December 2014, 00:40:07 »
Advice please chaps,  my outside temperature gauge is showing between 67 and 69.5C on the screen.
I understand that its not just to tell me what the weather is like, but exactly how will it affect the running of the car ? ( I assume it is telling porkies to the engine)
flyer 0712
Re: outside temperature sensor
« Reply #1 on: 04 December 2014, 00:54:05 »
Thought it just tells you the outside temp as I have just changed mine as the old one was reading far to high like yours but it didnt effect the running / heating of the car. :-\
« Reply #2 on: 04 December 2014, 01:06:15 »
Prefacelift & minifacelift the outside air temp sensor is just to tell you the temp outside, but on face lift cars it also talks to the a/c so your interior temp will be up the wall.
You need a new temp sensor which lives on the lower edge of the front spoiler in the middle. If a new sensor doesn't want to play (they're only cheap), then go back along the loom to the next connector & check for decent connections in the plug/socket.
chrisgixer
« Reply #3 on: 04 December 2014, 01:14:43 »
Face lift Climate control goes loopy with no temp sensor signal, can vouch for that.
Keith ABS
  • Maldon Essex
« Reply #4 on: 04 December 2014, 07:39:09 »
Had a similar prob on mine where it was reading mius 60 outside so it got extreamly toasty inside. Bad conections on the bumper loom plug on mine
Keith b
« Reply #5 on: 04 December 2014, 08:03:48 »
Sensor is easily dislodged by puddles etc... Sitting next to a warm radiator is enough to confuddle it...
Easily sorted with the bonnet open on facelift cars :y
amazonian
« Reply #6 on: 04 December 2014, 14:32:16 »
Thanks for that advice lads, better go and get one asap by the looks of it, will let you know result.
cheers
flyer 0712
« Reply #7 on: 04 December 2014, 15:18:35 »
well bless my soul..learn new things every day on here. :y :y
brendan1983
  • Hampshire
    • Omega CDX Saloon
« Reply #8 on: 04 December 2014, 15:31:16 »
Is the sensor the same for all Omega's?
Mines been displaying some odd info lately - pretty sure it wasn't 24c last night in Fareham at 2230
Thanks
2003 CDX & Yamaha Thunderace
andyc
  • Norfolk
« Reply #9 on: 04 December 2014, 15:33:21 »
All the same, Pt/No 9152245 £11.88 inc VAT
Andy
Thetford. Norfolk
chrisgixer
« Reply #10 on: 04 December 2014, 15:34:53 »
cheers
Yours is giving a reading though, (question to the electrickery minded members here) is it worth checking the loom plug on pas side for corrosion...?
4x4
« Reply #11 on: 05 December 2014, 16:21:39 »
Also fitted to astra,corsa,vectra etc pop down a scrappy and get a few :)
