Author Topic: Something knocking  (Read 2834 times)
Something knocking
« on: 05 December 2014, 13:18:56 »
These bloody speed humps are playing havoc with the suspension  >:( Got a knocking sound from the front driver side when going over the speed humps now  ::) Dont sound like drop links either  :(
Re: Something knocking
« Reply #1 on: 05 December 2014, 13:54:34 »
initial estimate wishbones
chrisgixer
« Reply #2 on: 05 December 2014, 15:42:01 »
So have I. ;D ffs..... ::) ;D
Plenty of guides in FAQ and maintanance about suspension diagnosis.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #3 on: 05 December 2014, 15:55:34 »
Same effect on mine was caused by vertical rear bushes gone on the poly'd 'bones. Pressed in two new OE bushes and it is now  fine :y
« Reply #4 on: 05 December 2014, 16:00:28 »
Ill have to jack it up and have a poke around  :( Going by the last batch of omega's it was drop links every time but they gave more of a rattling knock  :( Damn speed bumps  >:(
chrisgixer
« Reply #5 on: 05 December 2014, 16:40:50 »
It's not the speed bumps, but that pesky rearward vertical bush most likely.
Although mines something else. Single clonk once a week or so.
If you take the wheel off take a pic of the rearward wishbone bush and post it up.
« Reply #6 on: 05 December 2014, 16:49:11 »
Is this what you mean  :-\
chrisgixer
« Reply #7 on: 05 December 2014, 17:03:27 »
No ;D
You'd have more than a knock if that happened ;D
« Reply #8 on: 05 December 2014, 17:09:11 »
No ;D
Not quite sure what this part looks like then chris  :-[ So i can check and take a picture
chrisgixer
« Reply #9 on: 05 December 2014, 17:13:23 »
Have you checked the guides in maintanance and FAQ? One of them has a pic. I know it does, I wrote it.
« Reply #10 on: 05 December 2014, 17:23:23 »
Might be your top mounts.  I had a nasty knock when going over bumps/potholes and changed the top mounts which sorted the problem.  :)
« Reply #11 on: 05 December 2014, 17:30:33 »
Cant find anything in faq about rearward vertical bush  :-[
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 05 December 2014, 19:17:28 »
+1 :y :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #13 on: 05 December 2014, 20:46:16 »
This is I believe the rearward vertical WB bush that Gixer speaks of :)
RIP Paul Lovejoy
