Author Topic: Part number  (Read 3262 times)
Part number
« on: 05 December 2014, 16:33:11 »
Anyone help with the part number for Engine sump gasket on 3.0 mv6 please  :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Part number
« Reply #1 on: 05 December 2014, 16:51:42 »
Just clean it up with a bit of green scouring pad and some brake cleaner then apply a thin film of gasket sealant to both surfaces.
Wait for it to go off a little then bolt it all back together  :y :y
I used some Loctite stuff for both my gearbox and engine sump with no problems  :y
Re: Part number
« Reply #2 on: 05 December 2014, 18:42:19 »
They don't have one... Camcover goo on a nice clean surface as above :y
Don't forget there are two halves to the sump, upper and lower, and engine needs lifting about three inches to remove the upper half...
Re: Part number
« Reply #3 on: 05 December 2014, 21:14:54 »
Thanks TG & TA  :y Need to get to the strainer so guess its all got to come off .
chrisgixer
Re: Part number
« Reply #4 on: 05 December 2014, 21:23:37 »
Nope, just the lower steal pan needs to come off to get to the strainer.
chrisgixer
Re: Part number
« Reply #5 on: 05 December 2014, 21:24:10 »
Upper half often leaks though so if your feeling energetic, do both. Although... you'll need an engine crane to lift the engine to give clearance to do the upper half.
Re: Part number
« Reply #6 on: 05 December 2014, 21:26:33 »
I'll hire one  :)
chrisgixer
Re: Part number
« Reply #7 on: 05 December 2014, 21:28:32 »
Check if it's actually leaking first, perhaps?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Part number
« Reply #8 on: 05 December 2014, 23:23:18 »
Steve, can you let me know how much you get stung for renting a crane and where from? I need to rent one so I can get the 3.0l engine on a stand.  :y
RIP Paul Lovejoy
4x4
Re: Part number
« Reply #9 on: 06 December 2014, 11:51:01 »
Im sure a couple of noofers can lift it up on to engine stand  ;D
Re: Part number
« Reply #10 on: 06 December 2014, 13:34:06 »
I did wonder how you would get it ont stand but guess a hoist is the logical way  :-\ Dont think they are very expensive to buy anyway
4x4
Re: Part number
« Reply #11 on: 06 December 2014, 13:42:42 »
Stand £40 crane £120ish :y
Re: Part number
« Reply #12 on: 06 December 2014, 13:51:57 »
£27 a day for the hoist  :( All the faffing about , mite as well take it to serek  ::)
Webby the Bear
  • Northampton
Re: Part number
« Reply #13 on: 06 December 2014, 18:42:55 »
Where was 27 squid a day, Steve?
RIP Paul Lovejoy
Re: Part number
« Reply #14 on: 06 December 2014, 18:47:57 »
Here mate  :(   lift  not sure if its man enough though  :-\
