Author Topic: Tickover intermittent  (Read 2532 times)
John W
  • Westcountry
« on: 06 December 2014, 14:44:01 »
My 1999 MV6 manual has recently taken to losing its tickover intermittently. It's usually ok  from cold and will drive happily for a while (length of time/distance varies), but then will not tickover, and loses some power and drives lumpy (but still on 6 cylinders). Sometimes it recovers and drives fine again. If I park it till cold, its ok again. Any ideas?   :'(
chrisgixer
Re: Tickover intermittent
« Reply #1 on: 06 December 2014, 15:22:33 »
Your description covers a few common causes.
1 tickover or stalling alone symptom is usually down to the idle control valve on the side of the plenum sticking. A good flush out with crab cleaner and some light lube usually fixes that.
2 loss of power on all 6 cylinders could be anything from a maf fault to crank sensor which can also cause a stall.
3 engine temp related issues also points to crank sensor, as the cable is clipped to hot oil pipes at the back of the engine. Quite common.
4 don't count out a faulty coil pac, but probably least likely given your description.
I guess clean icv and check for engine fault codes here
http://www.omegaowners.com/forum/index.php?topic=90581
Code 19 is crank sensor
Then see how you go.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 06 December 2014, 17:34:05 »
Crab Cleaner!!!!!!???Where you buy that then?
4x4
« Reply #3 on: 06 December 2014, 17:36:22 »
Seaside ofcourse,where else would you buy it  ;D
chrisgixer
« Reply #4 on: 06 December 2014, 17:44:08 »
Carb cleaner. Silly !
« Reply #5 on: 06 December 2014, 19:03:54 »
Crabs... not nice. :-\
Easily cured however.
chrisgixer
« Reply #6 on: 06 December 2014, 19:34:13 »
...with crab cleaner...? :o that might smart a bit ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 07 December 2014, 13:43:46 »
I wouldn't spray crab cleaner OR carb cleaner anywhere near my piston!!!  ;D
RIP Paul Lovejoy
4x4
« Reply #8 on: 07 December 2014, 14:05:33 »
In your eye is also a no no lol  :D
John W
  • Westcountry
« Reply #9 on: 07 December 2014, 15:51:16 »
Hey, thanks guys! I 'll start with the Crab Cleaner (still have some from when I was single), and if that fails, I'll check out the crank sensor. The way it comes and goes, I suspect it'll be that.  :y Cheers.
« Reply #10 on: 07 December 2014, 21:15:44 »
..... I'll check out the crank sensor. The way it comes and goes, I suspect it'll be that.  :y Cheers.
have you done a paper clip test?
