Author Topic: Concerned Questions  (Read 4674 times)
Varche
  • middle of Andalucia
    • Golf Estate
Re: Concerned Questions
« Reply #15 on: 08 December 2014, 10:39:12 »
Where is the fun in someone losing control of a tramlining car on its 245 40 R tyres on 5 inch steels on bound coil overs with shot shockers?
You can still have plenty of fun in a well looked after car, modded within the law (assuming you aren't in one of the endless traffic jams or stuck behind a tractor with double white lines)......
That reminds me , I must get some coilovers and blue LEDs for our Corsa ;D ;D
« Reply #16 on: 08 December 2014, 10:44:32 »
There isn't any, but you're using an extreme example to justify the idea of introducing a law to remove all personal choice from the equation.
To ask it another way, where's the fun in me fitting 16" wheels all around to my MR2 and running bigger tyres for better handling, rather than the 15" front 16" rear fitted by the factory? You're proposing we ban that, just so that we can wrap everyone in a protective cocoon in case a dumb person does something dumb.. and a newsflash: if someone is going to do something retarded, the law won't stand in their way..
« Reply #17 on: 08 December 2014, 12:45:14 »
In your example, presumably you're bright enough, (i know you are), to use suitable tyres for the application in mind...
Fitting 205 width tyres on an Omega just because the 225/55/16s seem a bit expensive is a rubbish excuse... in that case, fit a set of early steelies which are, iirc, 195/65/15 and probably cost £30 each... but then I suppose they'll look rubbish ::)
I can see where Varche is coming from, but you're sadly quite correct, stupid people will do stupid shit as long as they're alive enough to do it...
Incidentally I saw a bright yellow MR2 buried in a post and rail fence yesterday... didn't look too healthy with bits of body work strewn fifty yards in every direction ::)
« Reply #18 on: 08 December 2014, 13:43:39 »
They're not for the inexperienced in bad weather - especially if you fit cheap taiwanese ditch finders (which Varche's proposed law wouldn't solve).. very easy to swap ends and tricky to catch given the short wheelbase (depending on age) and weight out the back. Oh yes, people also have a habit of switching from the staggered wheel widths to equal width front and back which moves the bias very much toward oversteer .. yes, that bit would be fixed by Varche's law (that's what I think we should call it now ;D) assuming people paid any heed to it like they do to the fact blue LEDs are illegal.. ;D
Not impossible to catch but you better be quick on your toes!
Anyway.. I probably got out of bed on the wrong side this morning, but the idea of "make the world perfectly safe by removing all personal responsibility and latitude for being different" annoys me no end.
« Reply #19 on: 08 December 2014, 13:57:44 »
I find putting the bed next to the wall helps... although having corrected yourself, you still get up grumpy, as smacking your nose in to the wall whilst half asleep does rather dampen the cheeriest of dispositions ;D
That MR2 looked to have understeered off a bend and been corrected and held along the fence line ::) took out 5 posts, but was stopped abruptly by the sixth one looking at the windscreen...
« Reply #20 on: 08 December 2014, 14:01:23 »
It takes special skills to make a mid-engined car understeer catastrophically ;D Or really, really awful tyres.
Actually, the Mk3 was setup for mild understeer from the factory - understeer safe, oversteer unsafe, so the bean counters would tell us. If you steam in too fast to a corner and don't do anything than heave on the wheel it'd often wash wide - trail braking was a good way to keep the nose tucked in, though.
« Reply #21 on: 08 December 2014, 14:16:47 »
my winter tyre set is that size.. and they dont look rubbish.. just looks like an old omega instead of those posh 18s  ;D
and the steering becomes very comfortable with them :)
ckz
  • burton on trent
    • Vauxhall Omega CDX
« Reply #22 on: 08 December 2014, 14:31:11 »
well, i didn't ask the original question to start a politic discussion.
there is a lot sheit mot rules about especially germany and belgium.
they are the worsest nanny states on it. all for the manufacterer and all needs to look the same.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #23 on: 08 December 2014, 14:41:34 »
Oh dear  ::)
Your car, your choice bud but put it this way.
16 inch wheels are designed to take 16 inch tyres  :)
16 inch tyres are designed to fit ................. you know what i'm going to say  :)
It doesn't matter what the things look like, its wrong, illegal and oppsing dangerous.
If you want to kill yourself, seriously that's fine bud.  Again, your choice but if you just get hurt please feel free to come on here so we can all laugh at you  :)
Pigeons and chess anyone  ;)
ckz
  • burton on trent
« Reply #24 on: 08 December 2014, 18:02:25 »
 :-X
195 ? never
205 ? no
215 ? maybe if no other Choice
225 ? yep, i found out they just right
235 ? maybe if they come on a good offer
as said before, smaller tyres are cheaper, yes, but safe, i oversteered bmw's before with small ish tyres on.
i like my car so i try staying on the road as it is not a 4x4.
try to get some time to go loughborough for the set up.
Thanks for the Tip.
