Pages: 1 2 [3]  All   Go Down
Author Topic: Brake fluid changing - does wheel order matter?  (Read 8552 times)
chrisgixer
Re: Brake fluid changing - does wheel order matter?
« Reply #30 on: 09 December 2014, 12:37:25 »
Jeez. The point is, you don't ordinarily need tech 2 to bleed the brakes. Christ almighty ;D
I though 4 years was the service schedule for brake fluid. (No tech 2 required, unless there's a problem )
« Reply #31 on: 09 December 2014, 14:42:22 »
But how do you know they don't nitrogen purge the bottles when sealing them, Chris ;)
Correct - nitrogen purge normal for hygroscopic products ;)
« Reply #32 on: 09 December 2014, 15:02:27 »
They do.
Plus even if it was air its a very small controlled amount and not 4 years of air circulated through the vent of a master cylinder reservoir.
Also remember that as your pads wear, more and more fluid gets pulled into the system via the lines from the reservoir.  :y
« Reply #33 on: 09 December 2014, 18:53:29 »
I thought the service interval for brake fluid was 2 years?
chrisgixer
« Reply #34 on: 09 December 2014, 18:55:25 »
Oh we're not interested in all that helpfull stuff TB. Nooooo ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #35 on: 09 December 2014, 19:00:48 »
Lol it is two years I believe. For most cars also I think.
As for cross contamination if fluid. . .
I empty the reservoir with a turkey baster and then stick in new fluid. Then to round and bleed. I never worry about the order. When it's coming out clean. .  It's done. End of IMO. You're not going to stop the old fluid from meeting the new unless you siphoned it all and refilled a totally empty system with new and then bled it of air. . . Which you were trying to avoid doing in the first place lol
Just my opinion.
RIP Paul Lovejoy
« Reply #36 on: 09 December 2014, 19:00:57 »
Well, I could say I had to use a Tech2 to bleed tractor's brakes when I first got it...  ...but not due to air in ABS.
Happy now?
« Reply #37 on: 09 December 2014, 19:02:16 »
Actually, MDTM and I had to use a tech2 at one of the recent-ish meets as well, now you mention it. That was due to air in ABS.
;D
chrisgixer
« Reply #38 on: 09 December 2014, 19:04:18 »
I was hoping to here about popping a piston out of a caliper on rusty. ;D
Wasn't sure it was actually needed on that occasion either, but as it was available....
« Reply #39 on: 09 December 2014, 19:13:53 »
In that scenario, it is handy to check there is no air trapped in some corner of the calliper. Esp as it was available.
chrisgixer
« Reply #40 on: 09 December 2014, 19:15:48 »
Couldn't do any harm, as it was indeed available.
(It wasn't needed though :y )
Pages: 1 2 [3]  All   Go Up
