Author Topic: fuel pipes  (Read 7670 times)
Diamond Black Geezer
    • & a silly coupe coming...
Re: fuel pipes
« Reply #15 on: 19 December 2014, 11:49:15 »
Ahhh, I see!!! There's another guy on here that has some pipes, assumed you was he, posting in wanted.  :y
Well, he's missed out, now I'm looking for some for you, now  :y :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #16 on: 19 December 2014, 12:00:06 »
V6 saloon mate all the way to the manifold if you can. Much appreciated :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #17 on: 19 December 2014, 22:01:35 »
Re: fuel pipes
« Reply #18 on: 20 December 2014, 10:16:03 »
can someone better in the knowhow double check am I looking for numbers 3 and 8 only?
http://www.partsbase.org/opel/omega-b-1994-2003-7--7-11-1-fuel-pipes-and-fittings-contd-x25xe-l80-y26se-ly9-x30xe-l81-y32se-la3-engines/
A little information is a dangerous thing...
You actually need #2 and #7 ;)
Type the part numbers into ebay.com... might get lucky at a dealer in the US :-\
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #19 on: 20 December 2014, 10:19:52 »
Yea noticed this morning 3 and 8 was estate. Thanks al. Do I need the 2 at the rear?
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #20 on: 20 December 2014, 10:21:35 »
4 and 8 or are they the ones on top of the tank?
Re: fuel pipes
« Reply #21 on: 20 December 2014, 10:21:50 »
You tell me ::) I can't see your old ones from here :P
Re: fuel pipes
« Reply #22 on: 20 December 2014, 10:23:33 »
#4 and #9,  have a clip one end and a hose tother, connect the lines to the tank :y
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #23 on: 20 December 2014, 10:32:53 »
Will get a 2 and a 9. Best be safe. Thanks al
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #24 on: 20 December 2014, 10:33:27 »
Sorry 4 and 9  :-[
Re: fuel pipes
« Reply #25 on: 20 December 2014, 12:13:20 »
Guess you're worried about the filter clips?
These can be replaced with 3-4 inches of ISO7480 fuel hose and four stainless spring clips either side of the filter.
Can use either another filter or a suitable length of stainless tube to join the return pipes together as well, but does rather depend on where and how you cut the fuel lines :-\
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #26 on: 20 December 2014, 12:28:00 »
Well couldn't unclip any of the pipes apart from ones at filter and at canister the rest got chopped and binned. So need all  :-[
Re: fuel pipes
« Reply #27 on: 20 December 2014, 14:39:48 »
That would do it...
EBay.com the part numbers :y Might get lucky...
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: fuel pipes
« Reply #28 on: 20 December 2014, 14:46:48 »
Bought them from gps. Not too bad all in for the 3 I was about 90 quid. Sore mistake  :'(
