Author Topic: side light bulb replacement  (Read 8318 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: side light bulb replacement
« Reply #15 on: 22 December 2014, 21:43:18 »
Thanks for the kind offer. I'll keep trying but if I'm not able, I'll ask my local garage to do it on the next service.
Midsomer Norton - I recall doing the carnival there (too) many years ago.
Regards.
The carnival has returned to Midsomer Norton recently.
As I recall, I locate the side light bulb by turning on the sidelights and observing where the other side (good) bulb lights up. After removing the rubber cover, I grope aroung that region of the dead light, find the lead to the sidelight, grasp it firmly near the bulb holder, wriggle it a bit, and it comes easily out of the light unit. I can then pull it up towards me, remove the bulb (push fit I think), push in a new bulb, and shove the bulbholder back into the hole in the lamp.
LostBloke
  • nth somerset
    • 2001 omega elite auto 2.6
« Reply #16 on: 23 December 2014, 19:13:03 »
O.K. You've talked me into it, weather permitting, I'll have another go in the morning.
Regards
« Reply #17 on: 23 December 2014, 19:14:47 »
Regards
Just up the road from you :) (BS10)
LostBloke
  • nth somerset
« Reply #18 on: 24 December 2014, 18:51:33 »
Hi RobG
Yes very close (BS20). You're welcome to pop in for a cuppa. I promise not to try and get you to fit my light bulb :)
Merry Christmas to you all.
terry paget
    • 3 Astras 2 Vectra
« Reply #19 on: 30 December 2014, 18:25:40 »
Only if you remove the grill...
Not with you. Main rad grill or the grilles either side of the front fogs ......... either way, MFL had lamps don't come out in 10 mins unless the bumper is removed.
Indeedy, PFL/MFL with washers, quickest way to get headlight out is to drop the bumper.  It is possible without, but takes longer.
How wise, TB.This afternoon I easily removed a headlight on my 1997 2.0 petrol estate in 5 minutes. Replacing it took longer - the bottom bolt. After half an hour I gave up, recalling your advice. Dropped the bumper, 5 minutes, then installed new headlight 1 minute more. Useful lesson learned.
Magwheels
    • 2.2 dti Elite saloon
« Reply #20 on: 30 December 2014, 19:27:16 »
Changed both of mine to LED's, it can be done without taking anything else off for access but it is tight!!
I have large ish hands and they did look like I had been teasing a cat after....but you can do it.
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« Reply #21 on: 10 January 2015, 19:35:48 »
Thanks, I'll give it another go. I'm in the process of convincing my wife that her wonderfully dainty hands were made for bulb changing  :y
Regards
Can I borrow your wife's dainty hands? Can't get mine in there. Gave up after about a minute.  >:(
LostBloke
  • nth somerset
« Reply #22 on: 06 February 2015, 21:02:26 »
Hi Lagondanet, sorry for the delay in replying. What with Christmas / New Year and multiple (enforced) visits to relations I've not had much time. If you can get my wife to work on a car in the cold you're welcome  :)
Regards
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #23 on: 07 February 2015, 07:32:15 »
Thanks for the offer.
