Pages: 1 [2] 3  All   Go Down
Author Topic: Other than a puncture.....  (Read 6633 times)
Re: Other than a puncture.....
« Reply #15 on: 18 December 2014, 20:50:31 »
I bet you're just about irresistible when you're turning red & stomping on a rusty foot pump to blow the tyres up on a 14 year old oversized Astra ;)
Just like I am when I do it.. ;D
Glad you said 'oversized'. The title of 'fat astra' belongs to the zafira.
The Omega is lithe and Gazelle like.*
*Facelift model only. ;D
« Last Edit: 18 December 2014, 20:54:07 by Doctor Opti »
« Reply #16 on: 19 December 2014, 10:57:21 »
I can't be arsed with pissing about and removing the tyres.
« Reply #17 on: 19 December 2014, 11:01:18 »
A decent tyre bay can have tyres off & back on again in minutes ......... they're not going to charge much  ;)
« Reply #18 on: 19 December 2014, 11:53:26 »
I had the same issue a couple of years ago and my local tyre shop charged me £10 to whip the tyre off clean up the rim and refit.
Job Jobbed!  :y
« Reply #19 on: 19 December 2014, 12:23:02 »
Job Jobbed!  :y
Tyre?....singular?
That's £40. ;D
« Reply #20 on: 19 December 2014, 13:38:19 »
Job Jobbed!  :y
Tyre?....singular?
That's £40. ;D
That's right M'lud, but you might get stung for even more if they see you coming!   ;)  :D  ;D
« Reply #21 on: 19 December 2014, 13:56:33 »
Ideally, when they fit the tyre and after they have cleaned the corrosion, they apply a bead of sealant which slows the corrosion and helps seal it
« Reply #22 on: 19 December 2014, 14:29:23 »
Not undertaken at 99% of tyre fitters then. ???
Taxi_Driver
« Reply #23 on: 19 December 2014, 18:01:21 »
Corrosion on the rim where the tyre is in contact with it is a very common cause for "slow punctures", esp if your tyre fitter is a cowboy (which most are TBH)
I've purchased the very latest technology from Ebay, to check that the valves are tight.
For my £1.20 I received 'a state of the art tightening tool' along with four new valves. Delivered by first class post so not much, if any  profit, I think.
Washing up liquid in water would do the same job  :y
I had the same, a couple of months back.....slow leak...turned out to be leaking valve....tyre fitter found it with soapy water....and new valve fitted  :y
« Reply #24 on: 20 December 2014, 01:18:57 »
Had this with the Jeep, tyres taken off, wheel cleaned, and replaced...... :y :y Alloys themselves can become porous over time.................. :) :)
« Reply #25 on: 20 December 2014, 17:24:34 »
Some alloy wheel types are prone to going porous, but fortunately for us, non of the Omega ones are prone to this.
« Reply #26 on: 21 December 2014, 10:17:40 »
Not even mine  :y :-X
« Reply #27 on: 21 December 2014, 11:10:49 »
Still going down. ???
I may change the valves just as a process of elimination. I'm not overly hopeful it will sort the problem though.
Looking on the bright side the foot pump gives me a good workout. I now have the physique of a Greek God. :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #28 on: 21 December 2014, 18:34:33 »
Dionysus I presume?   :-X
« Reply #29 on: 22 December 2014, 01:13:29 »
I bought an electric pump, that stops automatically once you put the pressure in it, used it a few times on the Jeep, not yet on the Mig or the Honda................. :y :y
Pages: 1 [2] 3  All   Go Up
