Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: Rear vented disc fitting kit  (Read 23664 times)
Re: Rear vented disc fitting kit
« Reply #15 on: 22 December 2014, 14:47:55 »
As only one spring is missing, am I right in saying that the rattle springs are the same across both rear callipers ?
According to Vauxhall, they are different but I can't see how the hell they can be if the pads are the same  ???
they're different. The spring spans the edge of the disc ..... vented disc is twice as thick  ;)
« Reply #16 on: 22 December 2014, 14:48:05 »
Don't panic...
Firstly, I was out on my pricing, I had to order a set for another car and they were nearer £45 from VX :-[
Secondly, Jason at Allgerman has confirmed that they are available as a stock item for about a tenner 8)
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #17 on: 22 December 2014, 14:51:07 »
Ahhh - I was about to suggest looking at other cars (later Vectras for instance?) which may have a thicker pad, and consequently longer pins. All good. And Allgermanparts the way to go!!  :y :y
« Reply #18 on: 22 December 2014, 14:51:47 »
20mm vs. 12mm.
FITTING THE NARROW SPRING TO A VENTED CALIPER WILL MOST LIKELY JAM THE PADS APART... ESSENTIALLY LOCKING THE REAR BRAKES OFF. ALMOST AS STUPID AS FITTING SOLID DISCS TO VENTED CALIPERS.
Apologies for shouting, but the point needed to be clear :y
« Reply #19 on: 22 December 2014, 14:55:08 »
..... ALMOST AS STUPID AS FITTING SOLID DISCS TO VENTED CALIPERS.[/b][/size]
but even the 'experts' in garages have managed to do that  >:(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #20 on: 22 December 2014, 14:55:50 »
20mm vs. 12mm.
Don't panic...
20mm vs. 12mm.
Message received Al, thank you  ;D ;D ;D
« Reply #21 on: 22 December 2014, 14:56:52 »
You're welcome ;)
« Reply #22 on: 22 December 2014, 14:57:46 »
Doesn't mean that they're not stupid...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #23 on: 22 December 2014, 15:16:23 »
My lokal factor does still list fitting kit for vented and non vented, different part numbers and the computa says vented or solid :y
Hoof'land storeman.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #24 on: 22 December 2014, 15:21:26 »
Spoke to Jason
Top Bloke  :y :y
Should be here tomorrow, 16 quid including the carriage so no complaints from me  :y :y
Thanks for the heads up Al  :)
« Reply #25 on: 22 December 2014, 15:24:34 »
Spoke to Jason
Top Bloke  :y :y
Bladdy hell!!! I was thinking of getting a set, having read posts, but thought 'well, obviously won't bother ordering a set now, they're never getting here before Christmas, might as well leave it until New Year' That's great service!!!!  :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #26 on: 22 December 2014, 15:34:01 »
Spoke to Jason
Top Bloke  :y :y
Yup, a few on here swear by him but today was my first time.
I must say, he was very gentle and never tried to force himself on me   Great service  ;D ;D ;D ;D
If your reading this Jase, you know were all friggin mad at this end of the M62  ;D ;D ;D ;D
« Reply #27 on: 22 December 2014, 17:27:43 »
Gm only...  Bear with me as out with the great unwashed but have part numbers at home ;)
About £10 for four pins and two springs iirc
Even trade, I think its more than that without the vat ;)
« Reply #28 on: 22 December 2014, 17:33:40 »
The last set I acquired in early November were well over that, about two thirds of what TG was quoted, but so much has happened since then, my mind has gone to mush :-\
But good to know a reliable, sensibly priced option is readily available  8)
« Reply #29 on: 22 December 2014, 18:13:45 »
Admittedly before my garage went, I think that trade was about £4 per pin, and a couple of quid per spring, plus the VAT.  This worked out approx. half the GM retail - I remember looking fully at receipt due to cost.
Pages: 1 [2] 3 4 5 6 7   Go Up
