Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Rear vented disc fitting kit  (Read 23431 times)
Ralph
  • Northumberland
    • 2.6 MV6
Re: Rear vented disc fitting kit
« Reply #45 on: 07 January 2015, 16:43:26 »
I take it from above then the kit for vented discs is MBA1271.
I've just received one from Camskill & they ain't going to fit, they look like they might fit none vented though.
« Reply #46 on: 07 January 2015, 16:49:12 »
Exactly :y
Ralph
  • Northumberland
    • 2.6 MV6
« Reply #47 on: 07 January 2015, 17:05:34 »
Well the MBA1271 kit I've received has pins 73mm overall length & the a/r Springs are only 47mm ?
« Reply #48 on: 07 January 2015, 19:20:24 »
In that case, either someone at the Mintex factory is a complete retard or they have no quality controls in place :-X
« Reply #49 on: 08 January 2015, 10:30:21 »
The kit for my vented rear discs didn't fit as the pins were too short. TB now has these.
I re-used the old pins.
When I contacted the seller he apologised profusely and gave me the rear pads for free (£15) in order to avoid negative feedback. :y
I'm happy with that. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #50 on: 08 January 2015, 15:31:03 »
Right, the friggin nightmare continues .................
Back brakes in many pieces and I can now confirm that the MBA 1271 pins are only 73mm long
The ones fitted are 85mm long  >:( >:(
Can I use the old pins and the new springs which seem slightly longer from the 1271 kit ?
Need to get mobile as i've just got another job (mobile stocktaker) and need to be ........ eh mobile.
Also I think i've got to the bottom of the dodgy handling ............ one spring was missing and one of the pads had separated from the pad plate  >:(
Ralph
  • Northumberland
    • 2.6 MV6
« Reply #51 on: 08 January 2015, 15:39:52 »
I've re-used the old pins several times but they are really past their best & the a/r springs have disintegrated.
I've re-ordered the other kit MBA1266 from Camskill I'll see what comes in that one.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #52 on: 08 January 2015, 15:47:11 »
The pins in the 1266 kit are only 62 mm long Ralf  :(
I've just been on the phone with camskill and they have given me a couple of part numbers from Budweig which may do the trick  :-\
I'm ringing a local supplier now so don't run away ................
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #53 on: 08 January 2015, 16:01:49 »
Right,  Camskill's have come up with these part numbers by a company called Budweg
They are BSF 0667 and BSF0711
Anybody know of them ??
« Reply #54 on: 08 January 2015, 16:12:56 »
What a palava :-\
If Mintex kits are that wrong that only leaves genuine...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #55 on: 08 January 2015, 16:23:11 »
Waiting for a call back from Budweg's office in Rochdale now  :y
I'll put my findings on here later if they get back to me  :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #56 on: 08 January 2015, 16:46:46 »
The kind lady has emailed somebody in Denmark who hopefully should be able to sort us a kit out that fits.
The nearest pins upto now is 91mm x 6mm
« Reply #57 on: 08 January 2015, 17:06:00 »
As a thought, MK2 Granada pins might be suitable... 2.8s had vented fronts, pins push through and are held by spring clips outside the caliper... Not sure of length/diameter but will investigate further :y
« Reply #58 on: 08 January 2015, 17:12:12 »
Tg, how does the spring in MBA1271 compare to my used one? Clearly if that is also wrong then the Mintex kit is less than useless :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #59 on: 08 January 2015, 17:25:14 »
I'd say that the 1271 spring is a good 8mm shorter on the pad side  :(
Pages: 1 2 3 [4] 5 6 7   Go Up
