Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Rear vented disc fitting kit  (Read 23514 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Rear vented disc fitting kit
« Reply #60 on: 08 January 2015, 17:39:05 »
It would only be a couple of minutes work to make new ones of whatever length I needed. Far less time than you've each spent on the phone.
What diameter are the pins? Hopefully it will be an off the shelf size. When I fitted new ones -to my solid discs- I binned the old ones, so have no way of checking
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #61 on: 08 January 2015, 17:51:22 »
86mm long x 6mm wide   The last 5mm is tapered off to fit inside the calliper.
Tbh, the pins can be cleaned up and made to hold in position with a blob of lead / solder on the head before fitting.
Imo, the biggest problem is the springs (or lack of one in my case)
« Reply #62 on: 08 January 2015, 17:59:24 »
Ok... Long and short is that currently noone apart from Vauxhall are able to supply the components  for vented rear discs... :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #63 on: 08 January 2015, 18:07:38 »
So yet another item to be bought against future requirements! :o :o :o
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #64 on: 08 January 2015, 18:18:49 »
I'll know more if they get back to me tomorrow
« Reply #65 on: 08 January 2015, 20:10:19 »
Might have a complete, albeit used set here if you get stuck :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #66 on: 08 January 2015, 20:23:27 »
Thanks Al, i'll give you a shout tomorrow mate  :-*
I've just spent the last hour cleaning the pins up with a wire wheel and they seem to have come up pretty well.
In morning, i'm going to remove the callipers providing I can prove the bleed nipple works and do the same then rebuild without the springs.
Need to be on the road asap now.
Not had a permanent job in over 4 years but today, i've just been offered one  :D  It may be friggin zero hours and minimum wage but they are expanding so it looks like i'll be busy and most of all, i'll be able to make grand plans and actually do something about them for a change :y :y
« Reply #67 on: 08 January 2015, 20:31:56 »
Good luck with it!  :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #68 on: 08 January 2015, 20:55:21 »
Thanks Andy  :)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #69 on: 08 January 2015, 21:12:07 »
Could drill caliper holes,were wasted part of pin goes into caliper body and use a roll pin.
 Mercedes use a pin with a small R clip, w123/124 chassis.
Hoof'land storeman.
  • Chatham, Kent
« Reply #70 on: 08 January 2015, 21:28:23 »
So, it's an appropriate length of 6mm rod, cross-drilled in a couple of places for r clips, or even a loop of lockwire. If you peen one end over, you'd only need one hole which would look more original if that matters to you.
That would take a couple of minutes, and a few pence worth of material. And you could have it done before you go to bed.
« Reply #71 on: 08 January 2015, 21:38:26 »
For the cost of them I'd buy new ...... not that I ever needed to replace them in my Omega or Senator or Senator or Carlton or  Manta or Cavaliar coupe .......  ;)
I did replace the anti-rattle cross shaped clips though ....... they rotted through  ;)
« Last Edit: 08 January 2015, 21:41:34 by Andy B »
« Reply #72 on: 08 January 2015, 21:43:57 »
Same as Mk2 Granada... wonder if Nick has any knocking around for comparison purposes :-\
  • Chatham, Kent
« Reply #73 on: 08 January 2015, 22:01:46 »
I've just remembered that one of the ways around this problem when you space Ford M16 calipers to go over vented discs is to use a long split pin. This is because the longer pins required are even harder to find than the VX ones we're talking about, and split pins are quick, cheap and easy.
« Reply #74 on: 08 January 2015, 22:08:26 »
Howsybout...
http://www.ebay.co.uk/itm/FORD-GRANADA-MK2-1977-1985-FRONT-BRAKE-PAD-PIN-KIT-FOR-VENTED-DISCS-BPF0983A-/331327611586?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d24aa22c2
87mm long...
Pages: 1 2 3 4 [5] 6 7   Go Up
