oh drat
Started by Omegatoy, 22 December 2014, 19:43:54
Omegatoy
well motor is finally out it fought me all the way,having been in there nearly 30 years,it didnt want to see the light of day! box was rusted onto the dowels,a cleverly hidden earth cable in the greasy morass that resided under the motor,and it popped up free as a bird,
started tranferring parts over to the new motor then noticed the spigot bearing in the new one was damaged, so popped off the flywheel ready to replace it with the original one that was in good nick,
well in donkeys years of playing with engines I have only seen this particular symptom once before on a road engine
:o
,she had snapped her crank off just in front of the rear main bearing! no wonder the box was jumping up and down,the flywheel was just a lump of floating steel on the end of the first motion shaft,being bashed every revolution by the broken end of the crank!!,
Quote from: Omegatoy on 27 December 2014, 18:31:19
'kinell! Good job the flywheel didn't make a bid for freedom. :o
Quote from: Omegatoy on 27 December 2014, 18:31:19started tranferring parts over to the new motor then noticed the spigot bearing in the new one was damaged, so popped off the flywheel ready to replace it with the original one that was in good nick,
:o
That's a Mitsubishi speciality! It is common on Shoguns and the smaller 4 cylinder engines.
I recovered a nearly new Lancer where the customer had picked up  'a lump of metal', which turned out to be the crank pulleys and the crank snout!
Omegatoy
Quote from: Kevin Wood on 28 December 2014, 00:12:02
couldnt go backwards cos of the first motion shaft length,still held on by the remains of the rear main bearing, so couldnt make a bid for freedom, just got bashed away till the motor cried enough, whipped head off today and not a mark on it all valves etc still good which surprised me!
Omegatoy
Quote from: Nick W on 28 December 2014, 15:27:38
:o
Maybe on the newer ones and the smaller 4 pots but not on the early ones, cranks do die with irregular oil changes i agree, but this one had done 3200kilometers since last oil and filter change,Personally i think it was metal fatigue after 29 years of going round in circles! :y
Quote from: Omegatoy on 28 December 2014, 18:24:15
Yeah,  I suppose they actually have to burst to get any worse. Seen a couple of nasty incidents in kit cars, normally because they've been lightened too enthusiastically. :o
Not fun when you consider where they are in relation to your ankles!
Broomies Mate
Quote from: Kevin Wood on 28 December 2014, 23:55:08
Forget the Ankles.......... About 3' from your happy sack.
Omegatoy
lol true enough,ok tried to add apicture but cant get it to load, who can do it for me if i send it to them, alternatively its now on fb but pretty sure a lot of you dont do facebook?
Varche
Well is it working yet?
I am sorry to say I had to drink your pint of Ruddles last night. Couldn't wait any longer!
Happy New Year :y :y
Omegatoy
Quote from: Varche on 01 January 2015, 20:19:27
SWINE!! rebuilt bottom end is in and bolted to gearbox etc,clutch control is all bolted up,just got to put cylinderhead, injectors,turbo,inlet and exhaust manifold,injection pump and pipes,turbo oil line,
balance belt,cam belt,covers for the aforementioned ,crank pulley,radiator and hoses,bonnet back on then see if it runs, :o
it was  a broken crankshaft,no damage i can see to gearbox,got pics of the crank that came out, in two pieces but cant get them to post on here, cant access me photobucket account either lol so they are on fb
Omegatoy
Omegatoy
hey thanks Entwood, ok will try to resize it, however it is a bit dramatic being that size! lol
aha think i got it now,its resized to message board?
Varche
Hmm, put the two parts in a dish washer then clean up well with something like wire wool and brake cleaner.
Then mend with something like Araldite Rapid Steel or similar metal glue. Try not to get too much on the join otherwise the crank would need rebalancing.
Quote from: Varche on 02 January 2015, 22:05:47
Typical Spanish back street garage repair, right Varche? ;D  Although you seem to be missing the step involving duct tape and bailing wire..
