Author Topic: Niggles  (Read 1821 times)
Niggles
« on: 03 January 2015, 12:31:22 »
I've got a few post head gasket change niggles.  :(
1) It dosn't start first time.  It starts second time, is lumpy for a couple of seconds, fires and then is fine. When warm it starts first time OK.  I'm wondering if the HT leads didn't like being moved about straightened out etc  :-\
2) LPG is taking longer to kick in and occasionally switches back to petrol when stopping at a junction/traffic lights etc.  Maybe related to above?
3) There's a slight squeak coming from the cambelt area when it's cold, the noise disappears when the engine has warmed up.  I refitted the same belt kit as it was less than a year old and was on about 15,000 miles.  Didn't James and/or Webby have a similar issue?  :-\
4) I think I have a slight coolant leak. Sigh... Mind you, given that I was putting more water in than fuel before, it's a massive improvement!!  :D
I've only done about 300 miles locally so far, so it needs a good run which it will get next week.  Any thoughts appreciated as always.  TIA!!  :y
Re: Niggles
« Reply #1 on: 03 January 2015, 12:40:16 »
Leak needs identifying as that could well be causing the lpg delay :-\
Re: Niggles
« Reply #2 on: 03 January 2015, 12:46:51 »
Hmmm that crossed my mind, but given that I was putting in a couple of litres daily before the HG change......  :-\
Re: Niggles
« Reply #3 on: 03 January 2015, 13:08:50 »
Depends where in the system the leak is as to what effects it might have :-\
Re: Niggles
« Reply #4 on: 03 January 2015, 16:26:47 »
I think webby and james'es were noisy but noise went away  :)
4x4
Re: Niggles
« Reply #5 on: 03 January 2015, 16:29:07 »
Might need lpg setting up,if battery was disconnected for a long time,check all vac pipes are ok aswell.
